Can anybody provide a date range and cultural ID for this weapon?
http://www.myArmoury.com/albums/displayimage....&pos=0
I'm especially interested in any published references you might provide.
Thanks!
Is this the one you're talking about?
http://www.myArmoury.com/albums/photo/1977.html
I ask, because different photos will show up if people just copy-past the URL from address bar, depending on how they're sorting through the albums.
The stat in the info area named "Direct link to this photo" is the correct URL.
If that's the piece, here's what I know of it:
Halbarte
süddeutsch, im Stil um 1500. Kräftiges geschwungenes Blatt mit spitz zulaufender Stoßklinge, Punktdekor, kreuzförmigem Durchbruch und drei tiefen sternförmigen Schmiedemarken. An der Rückseite vierkantiger Dorn. Zwei im unteren Viertel tordierte Schaftfedern auf Holzschaft. Länge 208 cm.
* Info from Hermann Historica
Halbarte
Last edited by Nathan Robinson on Mon 25 Aug, 2003 1:33 pm; edited 1 time in total
That was a mighty swift reply, Nathan! Yep, that's the one I was looking at. Windlass/MRL has something similar and I've wanted it for a while. Thanks for the tip about linking to the photos.
This site really is exceptional, by the way!
Best wishes,
Best wishes,
Here's a quick (and amusing) translation:
Halbarte South German, in the style around 1500. Strong swung sheet with pointedly approaching impact blade, point decoration, cross-shaped break-through and three deep star shaped forging marks. At the back four-sharp-edged thorn. Two in the lower quarter tordierte shank feathers/springs on wood shank. Length 208 cm.
Gotta love the computer translations. Haha...
Hey Sean-
I added this info to that photo's description..
One other cool thing about the albums is that you can comment on each photo and start a "dialog" about the photographs right in the albums. If people really start to take advantage of this feature, it could lead to a smaller discussion topic type thing that is specific to each image.
It's easiest to go into the albums and hit the "Last Comments" button to see the most recent things added. You can also go into a specific album and then choose "Last Comments" just to limit it to that album's photos.
It's not really being used yet, but it will be interesting to see if it ends up being appealing to anyone. I think it has potential, but then again, I love talking about specific swords and whatnot. :)
Pretty neat stuff. I like it.
OK, here's another go at the translation, using my rusty grammar school German:
Halberd
Southern German, in a style c. 1500 [indicating that this might be a later reproduction]. Stout, curved blade with a thrusting point, decorated with points, cross-shaped cutout and three deep, star-shaped smith's marks. On the backside, there's a square point. In the lower quarter, there's two [tordierte] langets along the wooden pole. Length 208 cm.
| Quote: |
| Halbarte
süddeutsch, im Stil um 1500. Kräftiges geschwungenes Blatt mit spitz zulaufender Stoßklinge, Punktdekor, kreuzförmigem Durchbruch und drei tiefen sternförmigen Schmiedemarken. An der Rückseite vierkantiger Dorn. Zwei im unteren Viertel tordierte Schaftfedern auf Holzschaft. Länge 208 cm |
Halberd
