Hi Guys
Can any one help with any information on 6th/7th century Irish swords?
cheers
Dave
You should try looking under Pictish and Gaelic swords, as appropriate to the region and people of that location and era. Several texts can be previewed for free showing the same basic form of sword from around 4th to 8th century. Ownership of a sword in that region and era is considered uncommon. There are a couple of examples surviving, but I have not had any luck finding a museum photo or stats for you. In appearance they are basically generic migration era style with only a flat bar portion of pommel remaining (similar to Peterson types O and P, although I doubt there is much taper to the blades of 6th and 7th century.) Consensus seems to be that most pre-viking era blades in that region were short. I will keep looking for something more detailed.
I recall some very bizarre swords from early medieval Ireland, with blades expanding towards the tip, with a sharp angle at the transition to the tip. Unfortunately I didn't save the information, and haven't been able to find it again though. Other then those, there's the short swords Jared mentions. Here's an example from the British Museum (5th-9th cent. AD, Co. Antrim):
Hi Jared/Joroen,
Thanks for the replies on this call for information which I put out on behalf of a friend who wishes to recreate a Irish raider of the period (?Scotti) .
There is some limited information on swords in the Osprey publications, 'Pictish Warrior' and 'Arthur and the Anglo-Saxon Wars' and interestingly Jeroen some are line drawings of the swords you have posted. I think it said they may have been some Moorish influence on these swords!! Perhaps not so outlandish when you look at the various cultural influences in the manuscript artwork of the Irish Clergy of the same period. Thanks again.
ta
Dave
ta
Dave
The thick tang I have seen also in a couple of langbardian swords who are devoid of pommel and cross.
Interestingly enough such blade has a decorated tang meaning that there was no organic matter covering it: it was used bare it seems.
I'm not so sure about that, Bruno. If I recall correctly, there are a number of finds that sport decoration in places where it would never be seen. That might be the case here, too. Looking at it I just can't imagine it being practical without hilt components. The decorations are interesting, for sure, though. Anyone else have any thoughts?
Short broad choppers (Roman era description, Tacitus) were described as having a very blunt rounded point in the 1st century A.D.. I suspect the photo example above is more representative of something prior to your stated 6th to 7th century period.
There is a narrow window around 6th to 7th century A.D. when Anglo-Saxon blades likely native to the region were probably not of Viking import/origin nor of a curved shape influenced by Moors.
Moorish swords of that time were straight and double-edged. But I find it very unlikely there was any Moorish influence on Irish weapons, even though there is some (ceramic) evidence for trade with Spain and North Africa. To me the Irish swords seem like a kind of survival of the Gladius. Ireland was a bit isolated of course. I wonder how many examples of these odd swords have actually been found?
Matt
Matt
Here are some images of swords (and other weapons) found at the crannog (fortified man-made island) at Lagore, Co. Meath, Ireland. They are estimated to be of 7th-10th century provenance and typify the native Irish work over and against the Viking imports that became the staple of later Irish warfare. The blade lengths of these swords averages around 18 inches.
One image is a close up of the swords from another (as will be evident enough).
Note, as well that the hilts of some are only partially present... even those that seem more complete are missing organic components that would have changed the overall appearance of the sword.
Hope this helps.
Attachment: 75.16 KB
Attachment: 86.06 KB
Attachment: 79.19 KB
Hope this helps.
A further note and a question or two:
Note: Although it is not clear in the above picture one of the spearheads appears to be tanged (no. 6 above), which is unusual for this era. You can see where two ferrules rest over the tanged section of the blade, which is also decorated. I could be wrong, of course, as these are artist's renderings rather than photos...
Question: I am fascinated by the socketed blade on the right-hand side of the bottom picture. It is described as a socketed "knife" and it certainly appears knife-like, but why would one go to the trouble of forming a socket unless one was going to affix the blade to something which would seem to be unneccessary given the apparent length of the blade?
Are there other examples of socketed knives from iron-age/migration contexts?
Could we be looking at an unusually shaped spearhead?
It's a beauty, either way.
Some more images from Lagore and related finds. The bottom pick contains an artistic rendering of the British Museum piece that Jeroen has posted above:
Attachment: 65.33 KB
Attachment: 127.46 KB
| David McElrea wrote: |
| Some more images from Lagore and related finds. The bottom pick contains an artistic rendering of the British Museum piece that Jeroen has posted above: |
It's in the Roskilde Vikingship Museum, and described as an Irish Viking period sword.
Jeroen, I can't tell you how long I've been wanting to see one of those swords in "real life." Thank you so much for posting that. I had no idea it was in the Netherlands now.
I also thank you for posting the artist's illustrations and the museum photo. I figured that anything "close" to viking era probably has been snapped up and deemed "viking"! For this post, the difference would be very blurred anyway as Scandinavian - Germanic connections with Gaelic in the Scottish - Ireland area probably occurred regularly by then.
| Jeroen, I can't tell you how long I've been wanting to see one of those swords in "real life." |
You're welcome, and thanks for the drawings you posted! :)
| Quote: |
| Thank you so much for posting that. I had no idea it was in the Netherlands now. |
Jeroen,
From the drawings I had seen, I had thought that the triangular portion at the shoulders of the first blade you posted was a result of grinding....however, looking at your photos, it looks almost like a ferrule that extends into a triangular langlet. Having seen it in person could you clear up which one it is?
Thanks,
Dan
Thanks,
Dan
| Dan Dickinson wrote: |
| Jeroen,
From the drawings I had seen, I had thought that the triangular portion at the shoulders of the first blade you posted was a result of grinding....however, looking at your photos, it looks almost like a ferrule that extends into a triangular langlet. Having seen it in person could you clear up which one it is? Thanks, Dan |
I've seen it 'in the flesh' a number of times and it appears to be forged in one piece. However, an x-ray may show it to be separate. You can't tell just by looking at it anyway, because of the corrosion.
Matt
Matt
Hey guys, just thought id jump in here to say great thread, especially the pics. I have heard of these swords a long time ago but never got the chance to see any. I also would like to recommend a book on the subject for anyone interested, Weapons and Warfare in Viking and Medieval Dublin which can be bought at the dublin museum website. Glad to see more people interested in Irish swords, keep up the good work guys.
Any clue on how the organic components looked? Did these swords have wooden pommels, like a roman spatha?
Further, how do they come out weight-wise? How does the diamond-section swords compare to the deeply fullered viking blades?
