I've been working on some research on and off based on Thom Richardson's thesis on the Tower of London armouries. Basically, I was trying to see if I could narrow down the point in time the steel cuirass begins to displace the coat/pair of plate in English harnesses.
Examining monumental evidence has been fairly inconclusive, but it at least got me into the ball park of 1350 to 1375, and from that, I began going over the Coram Rege accounts and Close Rolls, as well as the guild records that survive for the period to see if the orders for the Tower armoury gave a clear date. Unfortunately not.
Then I'd began to wonder, if I couldn't find evidence in the tower armouries for a clear transitional period, might I find a trace of it in a reaction in the weapons of the time? While I wasn't expecting a smoking gun, I did find something. It's regarding the type Arrows made for the English army.
A little background. First, there's the well known rolls extract before the Sluys campaign.
| Quote: |
| April 18. 1341
Westminster. To the sheriff of York. Order to cause 500 white bows and 500 sheaves of arrows at 12d. the bow and 14d. a sheaf for steeled arrows and 12d. for non-steeled arrows to be bought and purveyed and taken to the port of Orewell to be there at Whitsuntide next at latest to be delivered to those deputed to receive them, as the king needs a great number of bows and arrows for his war with France on account of the passage which he will shortly make to those parts in armed force, and the sheriff shall not omit to do this under pain of forfeiture. By K. |
Obviously the 'steeled' and 'non-steeled' references are the key bit. Most modern scholars seem to take this as evidence of some form of case hardening of a percentage of the arrows on issue. But in this case, I'm more interested in the fact we have a good date that shows the English were mostly armed with iron arrowheads in the early 1340s.
This is consistent with munition orders sent to the Sheriffs throughout the 1340s and 1350s, but in the late 1360s there's a change...
| Quote: |
| Feb. 5. 1368
Westminster. To the sheriff of Norhampton. Order, for particular causes, of the issues of his bailiwick to cause 600 sheaves of arrows in places where he shall see best to be made and purveyed of seasoned and not of green wood, as he will answer it before the king, and to be fitted with steel heads to the pattern of the iron head which shall be delivered to him on the king's behalf, sending the same to the Tower of London before Midsummer next there to be delivered to John de Sleford the king's clerk, keeper of his wardrobe in the said Tower, knowing assuredly that, if the same be not made of seasoned wood, the king will charge him with the cost over and above the punishment he will inflict. The like to the sheriff of Bedford and the sheriffs of 24 other counties, every sheriff for 600 sheaves. |
This didn't stand out to me at first. But it is the first time Edward specifically requests an arrowhead made to a pattern. It's also the first time he has specified 'Steel' and not 'Steeled'. 18 months go by and unlike every previous order for county arrows, there's a problem.
| Quote: |
| July 8.1369
Westminster. To the sheriff of Lancastre. Order, under pain of forfeiture, without any delay to cause the 600 sheaves of arrows by the king commanded, of seasoned wood and not of green as he will answer it before the king, to be purveyed in his bailiwick within liberties and without, fitted with heads of steel after the pattern of the iron head delivered to him on the king's behalf, and to come to the Tower of London there to be delivered by indenture to John de Sleford the king's clerk, keeper of his wardrobe in the Tower, so that they be there on Michaelmas day at latest, knowing assuredly that, if the same be not of seasoned wood, the king will cause the sheriff to be charged with the costs thereupon laid out, and punished by forfeiture; as the sheriff has hitherto taken no heed to do aught concerning the said sheaves which the king commanded to be purveyed and delivered as aforesaid for his service, and thereby the furtherance of the king's business affecting him and the defence of the realm is delayed, whereat he is moved to anger. By K. The like to the sheriff of Oxford and Berkshire, and to seven sheriffs of nine other counties, to purvey 600 sheaves in every county. To the sheriff of Norhampton. Like order, mutatis mutandis, to purvey and deliver 402 sheaves of arrows, arrears of the 600 sheaves commanded as above. The like to the following: The sheriff of Stafford to purvey 480 sheaves, arrears of 600. The sheriff of Essex to purvey 295 sheaves, arrears of 600. The sheriff of Surrey and Sussex to purvey 800 sheaves, arrears of 1,200. The sheriff of Lincoln to purvey 218 sheaves, arrears of 600. The sheriff of Notingham and Derby to purvey 407 sheaves, arrears of 1,200. The sheriff of Hereford to purvey 360 sheaves, arrears of 600. The sheriff of Bedford and Bukingham to purvey 881 sheaves, arrears of 1,200. |
As you can see from the arrears, it's been 18 months and the county Fletchers have barely been able to provide half of what Edward ordered. While there had been issues in the past, this specific order has met a more serious delay than any other. Why?
I think it's because the Fletchers hadn't previously had to source 'steel' heads locally. Certainly the Sleaford returns for the Tower show the heads begin to be manufactured at the Tower and headless sheaves begin to be ordered more and more frequently from the county from 1375 onwards. So why the sudden change from the earlier 'iron' and 'steeled' heads?
Am I perhaps reading too much into it or could this be evidence of widespread plate use from around 1365, at least widespread enough to force the English to change their arrows by 1368?
There's probably a ton I've not considered, so what does everyone think?
