I'd like to give Josh (of Davis Reproductions) a shout-out for the work he did on a recent commission.
I was after a version of the Italian rondel dagger Tod made at the beginning of last year (https://myArmoury.com/talk/viewtopic.php?p=327523). He recommended I approach Josh about recreating it.
This I did and was not disappointed by our initial discussion. He was open to my design ideas/alterations and my wanting to send him some of the materials, too.
Throughout the actual work, Josh kept up a steady stream of detailed updates, which I greatly appreciated. This allowed us to avoid the heartache of having to take the piece apart to fix an overlooked issue.
Long-ish story short, I'm very happy with both the process and the result, the latter of which speaks for itself, I think. Do keep him in mind, when considering a new commission.
Measurements (just the dagger):
Overall length: 43,5 cm
Blade length: 31,5 cm
Blade width: 2,6 cm
Blade thickness (base): 0,8 cm
Rondel diameter: 5 cm
Grip length: 8,5 cm
Weight: 291 grms
Overall, I wanted a Burgundian theme for this dagger, hence the firesteels, flint, sparks, St Andrew's cross and the initials of the 'last' ducal couple, Charles and Margaret. The colour scheme is based on Margaret's votive crown in Aachen cathedral, while there's also a link to Maximilian's Italian sword in the KHM (A170).
