The basic Andronovo/Srubna dagger is leaf-shaped to triangular with rounded indents at the shoulders, and a half-tang without rivet holes (presumably held in place by glue; I don't know what the hilt should look like, though). I'm not sure of the size range either, but they could be quite small. The other, less preferable option (although I do personally like it better) is the early akinakes used by cultures overlapping the Andronovo horizon in northern Kazakhstan and western Siberia. I actually had a pommel ornament cast for one of these.
Other than paying hundreds of dollars for a one-off casting (which runs the risk of failure with the old ceramic shell/gravity method, which would mean having to start from square one and make a new wax) the only idea I have at the moment is to get a bronze blade from Albion's moat sale, assuming they still have any, and reshape it with an angle grinder to make one of the simpler Andronovo blades. I think this is workable, but I'd rather avoid it.
Do you think there are any other possibilities? Something I've overlooked or a more creative idea?
