hello, i thought i'd share what i did lately, i made a gunstock warclub and modded a cold steel trail hawk for the fun of it.
for the gunstock warclub it was made from red oak that i finished with tung oil based stain and later on i added varnish.
as for the tomahawk i just added a walnut stain and pyrocarved a design. closer to the blade was from a pewter inlayed though the design isn'T as straight as i would like it to be it does give some flair to it and the further to the head it was inspired by ori's belt pattern from the hobbit movie it took about 3 days to do all the dots and my finger in the end couldn'T take any more of this lol anyway here's the pictures
about the green tape on the gunstock warclub, this was before i applied varnish on the warclub which completely messed up the contrast and washed a bit of the stain for some reason.... thinking of just burning the darkest textured spots... oh and the blade of the warclub is the tip of a DSA squire blade that i had for a long time but judged to heavy for the tang it had to use as a sword .
thanks for looking :)
Attachment: 214.63 KB
Attachment: 221.05 KB
Attachment: 139.22 KB
Very nice job on both! Just another example of how nice the CS hawks can be with a little talent and work! :D ....McM
thanks! i wanted to point out that for the gunstock warclub i did 90% of the work with a mini wood plane, took a while but i loved working on that :)
Etienne Hamel wrote: |
thanks! i wanted to point out that for the gunstock warclub i did 90% of the work with a mini wood plane, took a while but i loved working on that :) |
Etienne, long time since we communicated but I see that you are showing some real design talent with the War Club: I like the shape and proportions of the club.
Is the blade covered with tape to protect it from the vice clamping it down ? it's hard to see the shape of the blade.
The cold steel tomahawks are nice if one gets rid of the ugly black coating.
I used pain stripper on the black coating and removed it leaving a nicer grey finish on the steel on a Cold Steel Rifleman's hawk , this saves a lot of work compared to trying to sand off the very tough Cold Steel coating.
Someone not caring about the aesthetics and wanting to use the hawks can leave the ugly black paint as it does give some good rust protection.
The tomahawks handle looks very good also.
It's been a long time indeed! You are correct, the tape was to protect the blade i'm not sure about taking pictures though since the stain has been '' washed'' a little bit because of the varnish... i don't understand because i let it sit for minimum a week before applying a thin coat of floor varnish...
i used the paint stripper approach too for the ugly black paint of the tomahawk :) didn'T take long to remove it, i personally don't mind if it rusts because then i'd be able to remove it with some fine steel wool and add a bit of natural patina with time :)
the picture is from the less ugly side :lol: the other is truly not to my liking and floor varnish on a punch textured surface is very hard if not impossible to remove ^^' ah well, we all live and learn :P
Attachment: 169.57 KB
I LOVE how you left that teeny bit of fuller showing! That's first class. It LOOKS LIKE it was originally made with a broken sword blade. Outstanding! :D .....McM
thanks, it was a very fun project :) the blade took some time to shape due to the hardness, the ''not ruining the temper'' factor and the speed of the drill press for the sanding drum (i don't have a belt grinder so that's what i used :) ) .
i wanted to make a mini ball warclub but since i'd be making it with red oak planks just laminated together like i did this gunstock warclub i'd need to make it convincing :lol: nothing that can'T be achieved with a nice mini shaver :)
