Posts: 4,393 Location: Northern California
Thu 12 Nov, 2015 1:00 pm
I’m unsure about the history of DT5156 at this time over at Del Tin. In the early 2000’s they discontinued it. However, Albion liked it, and Del Tin made it just for them to distribute on their website. I bought one from them. As you can see, the hilt had changed, especially the pommel, which was now a very big type J. It’s still a brute of a sword, but much superior to the Windlass version. Like many Del Tins of this time, it had
distal taper problems. The blade doesn’t start to thin until halfway down the blade. Specs below:
Albion DT5156
Measurements:
Overall length: 44 inches
Blade length; 33.75 inches
Hilt:10.25 inches
Grip: 7.40 inches
Guard width: 10.3 inches
Blade width at ricasso: 1.90 inches
Blade width 16.5 down from guard: 1.70 inches
Blade width 2 inches from point: 1.5 inches
Blade thickness at ricasso:.190 inches
Blade thickness 16.5 down from guard: .190 inches
Blade thickness 2 inches from point: .139 inches
Pommel diameter: 2.60 inches
Weight: 3.95 lbs (usually it comes in at 4.2 lbs)
POB: 4.50 inches from guard
COP: 27.5 inches from guard
Type J pommel (DT5143)
Around this time Albion started a program to redo the Del Tin Grips. At the time the wood in these grips was suspect, and sometimes splintered after use. Albion replaced them with their won stabilized birch grips and re-wrapped them. These models have an A added (ADT5156) and have the Albion Makers Mark on the blade as well as Del Tin’s
Attachment: 94.48 KB
![DT5156.jpg](files/dt5156_511.jpg)
Attachment: 98.47 KB
![DT5156fulls.jpg](files/dt5156fulls_910.jpg)
Attachment: 98.08 KB
![DT5156hilts.jpg](files/dt5156hilts_156.jpg)
