This piece is a copy of a dagger that belonged to Henry VIII except that the original had etchings on the blade. The original piece has also lost its pommel and so I made one that may have been.... The scabbard is also lost and so I have made one to suit and it is rigged to hang at an angle rather than vertical.
The blade is 34cm/13.5" and 8mm thick at the spine and slowly tapers toward the tip and dives down over the last 2". It is hollow ground along its length and the spine has an angle running down it rather than flat as is usually the case.
The guard and pommel are steel and the grip is wire bound in bronze and iron and terminated in an iron turks head. The pommel has a bronze tang button and the blade is bonded and peened.
The scabbard is two layer leather with steel fittings and the hanging ring is mounted from a shell shaped bracket.
And I hope you like it..........
Next stop the US of A
