Go to page 1, 2  Next
Watch this: Rapier Time (photo-intensive)
This is a pretty interesting example of the craftsmanship and artistry that was not only possible in the early 17th century, but also a glimpse into the type of ornamentation that was valued then.
This example is a rapier and accompanying dagger that both feature a working clock in their pommels!
I'm hoping there are some German members out there that would be willing to translate the German descriptive text or a person who's versed in clocks and watches to shed insight on that element.
Rapier and Dagger, Saxony, 1610
[ Linked Image ] [ Linked Image ] [ Linked Image ]
Click any photograph to see the higher-resolution detailed version
what an extraordinary piece, I've never seen anything like it.
I see what appears to be a balance wheel, but without a balance spring (3rd pic, circular wheel on the left), and without a pallet fork
the circular wheel at the bottom appears to be the main spring, and appears to be wound by a crown which I'm guessing is the knob at the top of the pommel, which turns the top-most wheel.
I would guess that this sort of watch only told time by the hour, without displaying minutes or seconds because it was too inaccurate to do so.
The wheel at the top right is a bit of a mystery, since theres a few merged teeth at the top, which would seem to get stuck in the top-most wheel. Usually with date mechanisms, teeth would be MISSING, not merged, but I definitely know this watch does not have any complications whatsoever. Perhaps the merged teeth are to stop the winding beyond a certain point? Usually hand-wound watches are not stopped by this method.
this predates anything I'm familiar with, so these are just guesses. Any pics of the watch face?
Wow, nifty artifacts. I guess all that clockwork is to ensure that you're always on time for your duels...
Gordon
Are many of the dagger blade types from Saxony in that time period somewhat similar to each other? Because the few that I've seen or seen photos of have looked similar and IMHO gorgeous in their lines.
Alright, I have to admit that clockwork is pretty beautiful and fascinating on its own, but I probably would have never thought to combine it with swords - neat (though funky) idea! The detail work here appears brilliant, even if the sword mounts as a whole don't appeal to my tastes...
It is amazing how much of that description I can understand having only had 6 weeks of german! That is an amazingly ornate sword. I would never have though to stick eine Uhr in den Knaufen. ;)
:lol: That are so very german all over it, super schön uhrwerk,
good reason to have the sword with you out :D
:eek: when i read it with my octoberfest german, there are a bell in that sword pommel to, nice :)
Last edited by Patrik Erik Lars Lindblom on Mon 08 Nov, 2004 4:54 am; edited 1 time in total
Bizarre. It's like a classy precursor to those hiking boots one sees with a compass in the heel! I wonder how much use the sword saw, and whether the clockwork was easily damaged through the shocks incurred when fencing...
You know, the more I look at it, the less odd it seems. And, as has been noted by others, the quality of the craftsmanship is undeniable. It would certainly provide a talking point for a budding 17th Century socialite.
"Oh this? Why, it's my pommel watch of course. All of the stylish gentlemen are wearing them..."
I was able to verify that many watches of this period only had an hour hand.
I wish I had a photo of the faces of these two watches. But I don't.
Well the watchmaker is Tobias Reichel if my German hasn't totally failed me. You might try looking his name up.
Re: Watch this: Rapier Time (photo-intensive)
I'll try to translate if I can find the time...
I showed this to a few friends. After the "Oooh"s and "Ah"s were done, somebody said "Cool! You could put a frag-counter in your sword!" :lol:
I think I'm showing my age. :cool:
I just realized that the first photo shows the watch face on the dagger pommel!
The first photo also shows the watch face on the swords pommel,
and if you look close through rear lid face on second photo so can you see a bronze or brass bell to,
that one who dolphin shape hithammer will hit, on picture 3 can you see a small pice of it (bell) inside the lid. :)
Watch close! :D
Perhaps the rapier shows the hour and the dagger shows the minute?
So here is part one (the part about the Rapier):
182 a
Rapier and dagger, combined with a clock in the pommels, hilt is a work from Dresden.
The clocks are made by court-watchmaker Tobias Reichel, Christmas-present by duke Johann Georg to his brother, Kurfürst Christian II of Saxony, 1610
Rapier: blade with lenticular cross-section, slightly hollow-ground on both sides in the upper third, so called “Weihekreuze” (consecration/dedication crosses) stamped in there; indistinct smith’s mark on both sides of the ricasso.
The hilt is made of gilded brass, all parts are engraved richly with intricate floral ornaments, S-shaped crossguard, (…),
Vertically profiled wooden grip with wire-wrap of gilded copper with two twisted and two straight wires; two turk’s heads of the same material.
Flat pommel in form of a pine-cone (?) with a screwed-on spherical button. In the pommel: a clock with an hour-hand; on the front of the pommel: an engraved silver clock-face with a diameter of 30 mm; two kinds of digits can be found: on the outer circle roman digits: I-XII, on the inner circle Arabic digits: 13-24. Multiply profiled hour-hand made of blued iron (the hour-hand has been replaced). The clock-face is protected by a convex filigree lid. A full hour is indicated by s stroke on a flat steel bell. The clapper has the form of a dolphin.
(Here are quite a few technical terms from watch making which I can’t translate, it’s about details of the construction of the clock)
The rear lid is perforated with floral ornaments as a sound-hole. The sides of the pommel show engraved floral ornaments; in the middle of the back plate: filigree floral ornaments.
Overall length: 111 cm, blade length: 94 cm, breadth of blade at the ricasso: 2,8 cm, weight: 1020 g
Dimensions of the clock: length (without the button): 60 mm, breadth: 51 mm, height: 30 mm
Historical Museum of Dresden, Inv. Nr. VI 434
I realise this is extremely late but some words I couldn't translate and a very few others seem to contradict the pics. I have at last given up and will post what I have.
182b Dagger with Clock
Blade with rhomboidal cross-section; central ridge reaching nearly to the point; decorative, pierced fuller, a small area stamped with the initials <<W.B.>>Brass vessel, gilded and richly engraved. S-shaped quillons with oval parrying ring. Longitudinally shaped wooden grip with one smooth band alternating for every two of twisted gilt and copper wire terminating in two turk's-heads.
The oval pommel with screw shaped small pommel opposite/contrary to the clock; on the front of the clock is a gilded brass face with a tempered, blued, and complex shaped hour hand; the dial has a ring with the roman numerals I-XII; constant power transfer from the spring through the Stackfreed is achieved, Unrast with adjustable pins, the piece over the Ruckplatine(probably backplate) is stamped with the mark of Tobias Reichel. Front and back are vaulted through with a hinged cover of gilded brass. The cover is engraved with a bird and vines.
Overall length: 31.5cm, Blade length: 20cm, Blade width at false edge: 1.7cm, Weight: 200g
Measurements of the clock: Height: 27mm, Width: 23.5mm, Depth: 20mm
Dagger sheath: wood with black leather wrap; the gilded brass rechtige(this word generally means right or correct but I don't understand its place in this sentence) locket on the front of which are engraved vines and a bird beating its wings. Vines are also engraved on the back with Trageose. The chape is a downward pointing cone of gilded brass with spherical point engraved with a bird, an owl, and two vines.
The rest seems to be inventory information which I began to translate but then decided wasn't relevant to the set or of interest to anyone.[/i]
I'm not much of a rapier guy, but I need one of those to go with my watch cuff-links :D
That is pretty interesting. Thanks for the pictures, translation, and intersting discussion.
-Grey
Thank you so much, Allen. That adds a lot.
Very good translation, Allen
Just a few quick annotations:
The word "rechtige" you wrote reads "rechteckige" in the original text and means "rectangular", "Trageöse" means "carrying loop", "Rückplatine" does mean "backplate", I don't know the English words for the other expressions you marked either (I don't even know them in German :blush: )
I dug up some more photos of the inner mechanisms and watch faces of these unique pieces:
Page 1 of 2
