Posts: 2 Location: Canada
Wed 04 Feb, 2015 11:44 am
Help in idenitying Powder Horn
Posts: 1,265 Location: Malaysia
Tue 24 Feb, 2015 5:44 pm
Help in Identifying Powder Horn
I haven't seen this kind of powder horn before.
Any experts?
Posts: 1,241 Location: NC
Wed 25 Feb, 2015 4:23 am
Identifying powder horns, absent markings, can be somewhat difficult because they were made over such a long period of time and in many locations for different uses. Yours appears to be an antique based on the spout attached to the tip and the metal base. I believe it may be a military priming horn used by an artillery battery to prime muzzle loading cannon. It may also have been used on board a ship. The valve is adjustable for the amount of priming or charge required and the lever is, of course, used to open the horn and pour the charge. The end of the spout would be covered when the valve was opened so there would be, in theory, no direct connection between the touch hole of the cannon and the powder supply in the horn when it was actually used. The tip would act as a measure, holding the correct amount of charge until it was time to pour it into the touch hole.
Artillery horns were usually very large since quite a bit of powder was used to insure ignition and therefore a larger reservoir was needed so the horn would not need frequent refilling. Yours is a bit small for an artillery horn but that does not mean it wasn't. Valves of the type on your horn were used on a lot of artillery horns but also on horns used with other arms. There were a lot of different valve arrangements in use. If this is an artillery horn I suspect it dates from early to mid-19th century.
It is also possible that this is not an artillery priming horn at all but one used with a musket although, of course, paper cartridges were almost always used during the muzzle loading era, rather than horns.
Absence of markings is curious, if it is indeed a military issue horn but not unknown.
I hope this helps but surely others will also offer ideas.
Wed 25 Feb, 2015 8:26 am
Thanks Guys, Since I posted I found this on an Antique Site so at lest there is another one out there although it doesn't give any information on it.
http://oneofakindantiques.com/catalog/2582_an...horn_1.htm
I was hoping the time frame would be around the 1790's
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
