Onto the sword itself. In one word: wonderful! It is truly a remarkable design. Its robust blade tapers beautifully from the ricasso to the tip, which is acute but strong. A diamond-shaped blade profile sounds simple, but seeing it in person gives new appreciation for the execution of such a design. The blade is not razor sharp, but one should take heed in running a finger across the edge. The sharp section of the blade measures 31.5 inches, the overall length of the piece being just over 40 inches. A&A definitely delivered on the promised dimensions.
The swept hilt is eye-catching from every angle, its curves inviting the eye to lose itself amidst the flow of steel. I can see why the originals were blued; the finish not only increases durability but makes the white blade come alive in a striking visual contrast. The hilt is capped off by a large pommel in a shape that I would describe as a "flattened barrel." It does not lock my hand (3.5'' across at the first knuckle) in, but it interfaces quite well with the heel of my hand as the sword rotates during a swing. A perfect grip is provided by the (surprisingly regular and well-made) wire wrap, giving good bite to leather gloves while not shredding a bare hand in dry handling. Speaking of handling...
This is a substantial sword. The weight is definitely balanced toward the hand, which I like. Having never handled a sword before, this balance makes a lot of sense. When I pick up the sword, I immediately get a feeling of having the weight firmly in my hand and under my control. It feels a bit heavy, yes, but the weight is confidence-inspiring and easy to manage. "Relaxing" into a cut, as my instructor puts it, should be straightforward due to its heft. The sword never feels like it wants to fall out of my hand. Fingering the ricasso seals the grip and feels like the perfect way to hold this piece. It speeds up quickly and will readily swish through the air (no, not as dramatically as a fullered Katana).
Conclusion
The Stantler sword is my favorite historical sword. It represents (to my mind) a perfect blend of battlefield durability and civilian refinement to create a weapon practical in any context in which a sword would be appropriate. Its balance of thrusting and cutting capability are sure to make it a favorite of anyone who enjoys complex-hilted weapons and has the necessary wrist strength. As for a name, I have an idea. I see violence as an unfortunate, but sometimes unavoidable fact of life. The Latin term "Commisero," meaning a companion in misfortune, seems appropriate. What do you all think?
Recreating the shot that first drew my eye to A&A's offering.
