First is a smallsword with a simple loop hilt. It has a slim diamond schlager blade 30" long. Weighs 1.2 lbs.
Second is a longsword mounted with a modified Tinker/Hanwei blunt blade.
Third is a left hand dagger with a 12" Darkwood Armory blade.
Then there are two very simple rapiers with just a single side ring each. One has a 35" diamond schlager blade, and the other has a doublewide epee blade. They could both be remounted with other blades.
All are available. More pictures and prices are on the website if you see anything that catches your fancy.... www.jessebelsky.com/stageswords
