HOPE this is the right Forum - as this build is totally non-historical :).
This was actually completed around January - but with snow and re-carpeting the house, I just got around to taking photos...
Calenolf ("green branch") is my take on a Darksword Nomad with a longer blade. The guard and pommel were purchased from Darksword Armory under their Animal Rescue Network sword fittings offering. The blade is a bare HT Bastard with Fuller from KOA with a shortened tang. Pommel is threaded, countersunk, AND peened. A 6mmx1 Safety nut is included in the base of the pommel...
Scabbard is poplar, leather wrapped and back stitched using the methods I've outlined in my Tutorials. It took forever to get just the RIGHT Green leather shade for this project - a Forest Green, just a bit on the bright side.
Grip is a sandwhich wood core, wrapped tightly with cord and wood glue, then over-wrapped with 2 oz leather.
Chape is 22 gauge steel, formed by bending sheet and Silver Soldering the back seem.
Stats:
OAL: 42 1/4"
Blade: 33"
Grip+Pommel: 8 1/2"
Weight: 3.3 Pounds
POB: 2 1/2"
... and photos :).
Full sized images are at:
http://findlithui.deanandsandy.dyndns.org:8080/images/calenolf/
It was a challenge to get the scabbard throat area to JUST the right thickness to allow the guard artwork to slide over the wrapped core without scraping. But I wasn't about to hide this under a rain guard :).
That is straight-up beautiful! Very nice work!........McM
Beautiful work my friend! How do you achieve the rising in the handle and scabbard?
| Victor Sloan wrote: |
| Beautiful work my friend! How do you achieve the rising in the handle and scabbard? |
Thank you Victor :). All of these are 1/8" square leather risers. I glue my grips and cores very SLOWLY, working the riser edges with a bit of water and the best tool known to man - my fingernail :). By doing all of this slowly, avoiding pressure on opposing edges, I can generally get very high definition as long as I work with 2.5 Oz. leather....
Always welcome, my friend and fellow Tolkien fan! And thanks so much for the tips!
That's looking really nice. :) Sorry that's not the most technical appraisal, but it does look really good.
I really like how well the seam in the grip is hidden.
| Daniel Wallace wrote: |
| I really like how well the seam in the grip is hidden. |
Grin - and it's a butted seam, no stitching :).
On JUST the seam line - I start, and finish, with superglue to insure ZERO movement. I use Brendan Olszowy's "fingernail" method to mark and cut the finishing seam.
But there is another trick...
With both pre-dyed, and hand-dyed leather, denatured alcohol tends to be a dye solvent. Post glueing, wet a Q-Tip, or artist brush, with denatured alcohol, and slowly run it down the seam. This will cause the dye to "run" just enough on the cut edges to force color blending with the main body of the leather.
