Right. I've been looking around for ages for a sword that would fit my 14th/15thC archer kit. Couldn't really find anything within my price range that seemed right so the only option is to make one. Simple!
Never done this before, so bear with me and if any of you spot mistakes or things I'm doing horribly wrong please do jump in and offer advice etc, it would be most appreciated!
_________
I've opted (after much deliberation) for the Windlass Erbach blade to serve as my base. I wanted something without a fuller, wide at the base and around 33" long. This is slightly longer, and perhaps not exactly the profile of the period - a more defined taper and rib would probably have been more suitable but I just couldn't find any bare blades or cheap swords in the UK which fulfilled all of these criteria.
I stripped the tacky Windlass grip off, and split the wooden grip using a chisel, putting it aside in case I decide to glue it back together and re-shape it for the new sword, rather than carving a complete wooden grip core from scratch. The cross and pommel were removed, and I've been using them to experiment with aging/bluing techniques (Birchwood-Casey Perma Blue is pretty amazing, although while the cross went a nice aged blue-black, the pommel went almost totally black so I'll need to strip and re-try to get a consistent finish)
Not sure yet if I'll be taking off some blade base and turning it into tang - I'll need to feel the balance with all my fittings but without anything on the blade at all, and considering I'll be losing a good few inches turning this bastard sword into a single-hander it looks like I'll need to as the balance is awful.
Anyway, I've got a student (I'm a guitar teacher) who owns/works in a milling factory, so I've commissioned him to make me up a pommel and guard based on a design I came up with and drew out. It's almost a carbon copy of the superb XVIIIa.3 sword in the Met (thanks Sean!) and the pommel is a simple type J.
Not having done any of this before, I decided to make up a paper/card mock-up of the guard in 3D to see how it looked on the blade, and I'm fairly happy with how it came out. I've used the exact same blueprint I gave to my buddy doing the milling for me, so it should come out just the same.
Here's a couple of pics of the card mock-up fitted on the blade
Obviously it's a tad blocky and chunky, the edges will be faceted and rounded to a degree, making it slightly smoother looking, and the tips look wider in this model than on the design - they narrow from 1" wide in the center to 0.2" at the extreme ends.
Anyway, long-winded post over, I'll be updating this thread as the sword progresses, but any thoughts, opinions or criticism will all be most welcome, as I am utterly and totally clueless when it comes to building/working on swords and I have to learn somehow!
