“Probably dates ca 1680-1700 and is very Spanish in form. Very good condition for age and complete in all respects. A good honest example.”
The sword is in sound condition. quillons were a little loose, I have since shimmed them and everything is now tight. Grip covered in what seems to be embossed sheet metal segments. (Silver?)
Stats:
Weight, sword: 2lb 7oz (1.09kg)
Length overall: 44'' (112cm) Blade: 37'' (94cm)
POB: 3'' (8cm)
Profile taper: 1.26'' (32mm) at ricasso, 0.97'' (24.7mm)at mid blade, 0.64'' (16.4mm) 2 inches from tip.
Distal taper 0.32'' (8.2mm) at ricasso, 0.15'' (3.8mm)at mid blade,. 0.09'' (2.4mm) 2 inches from tip.
Markings:
Inscription in fuller on both sides of the blade, looks like “DOMINO MI?? ADITUTOR”
Inscription might be DOMINO MI ADJUTOR which means Lord My Helper.
Anybody got any other suggestions? The original seller thought Spanish, any better ideas?
Also posted on Sword ForumInternational
