I came across these two images that both fascinated and confused me:
http://manuscriptminiatures.com/4974/15435/
http://manuscriptminiatures.com/4970/15404/
In the first image, there appears to be two belts; (1) a narrow belt, worn high on the waist, to secure the surcoat; and (2) a wider belt worn lower on the hips that appears to be the sword belt. (The second image only shows the latter sword belt.)
Curiously, though, the sword belt seems to worn on the outside of the scabbard.You can try to rationalize these images by saying it's "artistic license" or that the artist erroneously depicted the sword suspension. But I kept seeing this identical sword belt suspension over and over in the illuminated manuscripts, all depicted the same way by a variety of artists. Convinced that this was an accurate depiction of a sword suspension method, I kept looking.
Then I found an article The Sword Belts of the Middle Ages by Albert Hartshorne in the Journal of Archeology, Volume XLVIII (47), from the year MDCCCXCI (1891). In this article, Hartshorne actually delves into the matter of this very same sword belt/suspension.
Hartshorne examined the effigy of Gilbert Marshall, Earl of Pembroke, who died in AD 1241. Photos of this effigy are presented here.
The sword belt that is worn on the outside of the scabbard is actually attached to the scabbard by leather thongs, and is actually the primary sword belt.
