Posts: 1,504 Location: Brisbane, Australia
Thu 09 Jan, 2014 3:30 pm
Quaddara (with variation in the spelling) is the Persian/Iranian name.
Bebut is, AFAIK, the Azeri name. They're quite common in Azerbaijan (or, at least, used to be).
In Russian, they are usually called kindjal (which is also used for the straight double-edged blades).
So, perhaps, if you want to know the "proper name", it is necessary to know the region of origin.
There might be naming differences for the curved double-edged blades and the curved single-edged blades (single-edged, neglecting a short back edge). The Russian military ones are double-edged (unless I'm confused by bad replicas), which are often called "bebut" to distinguish them from Russian military straight kindjals.
Some further discussion of these, and similar, swords:
http://www.swordforum.com/forums/showthread.p...e-of-Sword
http://www.swordforum.com/forums/showthread.p...nd-kindjal
http://www.vikingsword.com/vb/showthread.php?t=2528
http://www.vikingsword.com/vb/showthread.php?p=58614
