from now on i will never say the Chinese Ming dynasty armour is frumpy。。。。XD
it's so funy! ....and...a little cool
There are Chinese armed police mobile troop soldiers with brigandine and extra armour on southeast coast in middle of 16th century..
Well, you don't see that every day. It looks awfully imbalanced with all the armor on the left side, and I cannot see the wisdom in leaving the defense of the empire in the hands of men armed with small trees. :p
What is the context for those illustrations? Could someone translate the text?
Is it bulletproof?
If it's meant to stop musket shots, it would be thick, and that might make it worthwhile only covering the side facing the enemy.
Michael Wiethop wrote: |
[...] and I cannot see the wisdom in leaving the defense of the empire in the hands of men armed with small trees. :p |
It's part of a combined-arms unit. The main offensive element in the unit is spearmen, with long spears. The multiple tip bamboo spears are to stop the enemy from closing with the spearmen. There are sword and shield men in case the enemy gets past the multiple tip bamboo spears.
Sometimes, they just used a bamboo with the branches left on, and sometimes they used a bamboo pole with iron "bamboo branches" attached.
See http://en.wikipedia.org/wiki/Ji_Xiao_Xin_Shu for some more info on the Mandarin Duck Formation.
Timo Nieminen wrote: | ||
It's part of a combined-arms unit. The main offensive element in the unit is spearmen, with long spears. The multiple tip bamboo spears are to stop the enemy from closing with the spearmen. There are sword and shield men in case the enemy gets past the multiple tip bamboo spears. Sometimes, they just used a bamboo with the branches left on, and sometimes they used a bamboo pole with iron "bamboo branches" attached. See http://en.wikipedia.org/wiki/Ji_Xiao_Xin_Shu for some more info on the Mandarin Duck Formation. |
Michael Wiethop wrote: | ||||
you r right~~really looks like
This is leather armour……however,on Japanese experience,1cm+ thick Laminated leather with resins can stop medium caliber firelock bullets. Besides, in that time, southern Chinese leather armour was often coated with a thick layer of ceramic particles on the surface .
And the “LangXian”bamboo pike is a pure defensive weapon. It was used for the battle between Ming Empire armed policeman and the pirate which the Japanese wandering samurai head. AND, the Ming’s troop has made a loss exchange ratio:10:1000........with this funny weapon..
it is so easy to use: put a large clump of bamboo with steel pike head on your face and body……you will can not raise your arms and use any weapon(like katana,wakizashi... )......then, you will be poked to death by other pikeman.......
yep~The pirate had insufficient pole-arms with. It's an extreme disadvantage when facing to this bamboo pike
X Zhang wrote: |
This is leather armour……however,on Japanese experience,1cm+ thick Laminated leather with resins can stop medium caliber firelock bullets. Besides, in that time, southern Chinese leather armour was often coated with a thick layer of ceramic particles on the surface . |
What is the source for this? Are there any surviving examples? Have reconstructions actually been tested against firearms?
Dan Howard wrote: |
What is the context for those illustrations? Could someone translate the text? |
The very approximate translations I was given:
Upper left: Leather armour right hand side.
Upper right: Something to the effect that the leather armour can be worn in the saddle, and that the lower part can be lifted up and hooked for greater convenience.
Lower left: Leather armour back view.
Lower right: Leather armour front view.
In Chinese, the character used to describe this defence is the equivalent of “armour”. Elsewhere, the character for “skin” or “hide” also appears.
But what is the context? Does this image come from a contemporary writer or is it a guess by someone from a later period? If it was European I might ask whether it was a primary source or a Victorian source.
I'm not certain what the exact context is. However, every Chinese person I have shown it to says that the writing is very old, (one person compared it to Shakespearian English), which suggests that the original may well have been written in the Ming Dynasty. But whether it is originally from there, or a later copy of an earlier text, I cannot say. Similarly, what the text's purpose was, and why it was written, is unknown to me.
Taking a risk here with Wikipedia but they have this picture
http://en.wikipedia.org/wiki/Eskimo
About half way down
Which looks a lot like the armour in question
Cheers mat.
Attachment: 58.01 KB
About half way down
Cheers mat.
Dan Howard wrote: | ||
What is the source for this? Are there any surviving examples? Have reconstructions actually been tested against firearms? |
Same sentiment, if indeed laminated leather could stop firearms then I wouldn't get the sense why Japanesse Warlords sought after and stylized Early Modern European armor, the triple layered or thick breastplates ie Nanban armour.
Also, where is the evidence for Chinese leather armour that was covered with ceramic particles? How is this coating supposed to have any effect on its protective capacity?
Dan Howard wrote: |
Also, where is the evidence for Chinese leather armour that was covered with ceramic particles? How is this coating supposed to have any effect on its protective capacity? |
Dan, bullet proof trauma plates that soldiers insert into their kevlar vests are basically ceramic plates
Philip Dyer wrote: | ||
Dan, bullet proof trauma plates that soldiers insert into their kevlar vests are basically ceramic plates |
Do you really think that the Chinese had access to boron carbide or silicon carbide ceramics? As far as I know they weren't developed until the 20th century. Even if they did, how does a coating of these particles stop a bullet? Ballistic ceramic is 3/4" solid plate, not fine particles.
X Zhang wrote: |
One centimeter of leather can't stop a bullet no matter what you coat it with. It would need to be that thick just to stop a heavy bow. Some boofhead probably discovered that they used a ceramic powder mixed with the lacquer on leather armour and wrongly assumed that it had some protective capacity. More likely it was just a colouring agent.
By the way, I have a translation for the top right image that comes from someone who teaches Chinese literature:
"A set of armor is equipped at the left side. In case of inconvenient situations such as climbing mountains, crossing water or riding horses, the part of armor below the belt can be lifted and hitched with a hook; in this way, one can move freely and easily."
The addition powdered glass and other hard materials to leather armor was known in Europe and the Middle East as well. See the following thread on Armour Archive, relevant excerpts given below.
http://forums.armourarchive.org/phpBB3/viewto...p;t=131492
Ashmole 1389, p.36
That is,
How to make a doublet of defense
Take leather that is half-tanned and dry it, and shave the flesh side; and take glue with water, and set it over the
fire, and melt it with water, and then when hot lay it upon the leather on the flesh side, and strew thereon the powder of
glass beaten in a brass mortar with filings of iron mixed together; and then lay another piece of the same leather
flesh side to flesh, and nail it to the form and let them dry, and then neither spear nor edged tool will enter therein.
Ashmole 1389, p.36
Quote: |
For to make a doblet of fensce:
Take lether that ys half tannyd and drye hym, and schave the flesshe syd; and take glwe wt water, and set yt over the fyere, and melte yt wt water, and then al hote ly yt a pone the leder on the flesshe syde, and strawe ther on the powder of glasce bete yn a brasene morter wt fylyne of yrene y mellyd to geder; and then laye a nother pece of the same lether flesshe seyde to flesshe, and nayle hym to the scylde and lete hyme drye, and ther nother sper nother ege tole enter ther ynne. |
That is,
Russ Mitchell wrote: | ||||
From Nicolle, David. Jawshan, Cuirie, Coats-of-Plates: An Alternative Line of Development for Hardened Leather Armor, in Compantion to Medieval Arms and Armour, ed. David Nicolle, Boydell Press 2002.
There are several recipes, much too long to transcribe here, but I'll transcribe one sample for y'all: [p204]
Is it bulletproof?
IIRC, Peterson gives an account of the Virginia colonists trying to impress the natives by showing them a leather shield which resisted shot, but after it was pierced by an arrow, the colonists scrambled for a steel targe to have the native "re-do" the test.
Page 1 of 2
