1095 High Carbon steel
3/16ths" thickness
Blade width 2 inches at shoulder
Blade Length 11 inches
Grip length 4.5 inches
Grip material, Rust colored Leather wrapped over a wood core
Hilt is ground from mild steel and has been permanently hot peened to the tang for durability and historical accuracy. blade is fully sharpened and heat treated to a spring temper. The geometry is Hexagonal cross section terminating into diamond cross section at the end of the fullers.
So anyone out there who feels like "its too hard" or "this is beyond my skills" No its not! you can do anything you put your mind to! All you need is the will to act. Thanks for reading.
