I was contacted recently to to make reproduction of this rather iconic sword held in the Royal Armouries at Leeds. The original is a rather striking piece in that is has this rather unusual and frankly odd pommel and the writhen quillons and grip to go with it.
The client wanted a piece based closely on the original but also with scabbard and belt. The style he was looking for is where the belt appears to be wrapped around the top of the scabbard and has no mid point suspension so the sword would have to be worn quite high and falls straight down the leg; or more likely falls behind the leg when seated on a horse.
These scabbards shown in the effigies often seem to have this medial ridge and a metal mouth fitting, although it serves no structural purpose.
This piece also needed to be gold plated. This is a finish that I generally avoid from choice as you have to get a very even and high polish on the piece prior to plating and that means the gold comes out rather artificial looking (IMHO). I would love to use fire gilding, but this is out of the question these days as it is prohibitively expensive, but I decided to try anther approach on this piece where I applied an initial plating process, followed by the usual nickel and then gold. The result is something much closer to fire gilding in appearence.
The timescales for this piece were very tight and so I approached Craig at Arms and Armour who I know provides a sword based on this piece and he sent me a casting set of the hilt in bronze as per the original. I used these as the base for my sword, remaking the spacers to suit my grip and then applying my new 'fire gilding' base before having them gold plated. The grip is black horn carved to a twist. Craig seems particularly keen on the scabbard fittings it seems!
The scabbard is a wood cored as usual with a vegtan leather outer and plated steel fittings. The belt has plated bronze fittings and is black outside and red inside.
This sword has a blade length of 860mm/34" and is 42mmx7.5mm at the hilt. Overall it weighs1280g/2lb 13oz
I hope you like it and if there is anything you would like to know please ask away.
