Del Tin DT5134 "Maciejowski" Falchion
For quite a while, I've been considering this falchion and have finally bitten the bullet and ordered one. As a sword, I don't think it'd be all that great..but a cleaver - a real "zombie-chopper"?? I suspect it'd excel at that :D
I have a couple of questions for the knowledgeable folks here. Firstly..does anyone know of any surviving specimens of a falchion like this? Photo's would be lovely :D
Also..do you think something like this would be carried in a simple leather sheath, or just slung by a cord over a saddle ? I can't see it being possible to make a normal, wooden-cored scabbard for a blade shaped like this that wouldn't be totally impractical ?
Re: Del Tin DT5134 "Maciejowski" Falchion
I have one of these and I like it a lot, makes a great chopper and could see it as useful as a survival back woods tool in a modern context.
A wooden scabbard would have to be wide mouth and sort of need a way to secure the chopper in the scabbard or be fitted to shield from the sharp edge but opening along the top and retained by a securing strap near the narrow part near the handle.
If sharpened it would seem hazardous to have it flopping around loose on a saddle or on one's waist.
As a sword the handle is fairly long but the blade fairly short but I could still use it defensively as a longsword but the lack of a guard would have to be compensated for by being careful. The reverse side with the points I see as useable like a flanged mace with only one flange and for hard parries sparring the edge from damage.
Oh, and as far as I know there are no surviving examples of these unfortunately.
I had e cheapy dao sword once that had a scabbard that would work for this. The thing had only one edge, and the scabbard held it edge down. The back edge of the scabbard (or what matched up with the back edge of the blade) was open so that the sword would fit.
It was a lot like this one (perhaps the same one) that they have here on KoA
http://kultofathena.com/product.asp?item=KS5900B
I hope that helps with the scabbard question.
I'm in the process of making wood-cored scabbards for a pair of these, one blunt and one sharp. I'll post pictures when they're done.
The Indo-china region has a lot chopper-style implements in use, even today. Broad blades with no point, carried in sheathes made of wood or better, woven rattan, basket-like falt tubes, wide enough to accpet the wider part of the blade. Those sheaths are being carried on a cloth baldric or by the belt, suspended from a large wooden or horn hook.
Lots of historical art depicting them, but no surviving artifacts that I know of either. I really like these, it's a shame we can't seem more detail on them.
By the way, are there any other manufacturers of this type of sword?
