Greetings! Recently a question arose regarding a likehood of using brigandines in Britain in the late 14th and early 15th centuries - there is plenty of information regarding second half of the 15th century, but what about the early part? For example, how likely is that man at arms could have used a brigandine in Agincourt? Is there any documentary or iconographic evidence? As far as I am aware, there is no actual findings of parts of such armour, or am I wrong?
Probably a brigandine is too late for beginning of the 15 century.
But a coat of plates will do
ben
ben
Ben Anbeek wrote: |
But a coat of plates will do ben |
Well we have samples of brigandines from the time period - Chalchis beeing the best known, of course, also from Livorno area. The question is more in regards of possibility of it beeing used in Britain.
Artis, Could you post some images or links on brigandines from Livorno?
I haven't heard of any brigandines from there...
As far as I know, There are some examples of transitional brigandines, but they are called corazzina and there are some examples on the internet.
This is descriebed as the armour of Charles VI (1368-1422) . I think it is a good example of 14/15 century brigandine.
(source http://www.mallet-argent.com/images/brig%20and%20gauntlets.jpg)
I am attaching a couple of pictures from the finds in Livorno area - like I said, the placement of plates is questionable, but they are hard evidence of their existence.
Michal, I am a bit doubtful about the possibility of this armour being from the late 14th century - it's construction appears to be more like second part of 15th century, judging from the size of the plates. Can you give any more information about that particular brigandine?
Attachment: 22.48 KB
Attachment: 25.16 KB
Quote: |
Michal, I am a bit doubtful about the possibility of this armour being from the late 14th century - it's construction appears to be more like second part of 15th century, judging from the size of the plates. Can you give any more information about that particular brigandine? |
This brigandine is commonly attributed to Charles VI, anywhere I can see.
It is, as it can be seen, connected with hourglass gauntlets and the rest of armor pieces from around that time, in Chatres Catedral, I believe.
If it is properly dated, is another question, of course, but it's being called c.1380
