The TOP blade is forged from L6, got too wide at the base, and I ended up pushing the fuller out way too much, leaving it with and unusually wide fuller base, too much profile taper, and too acute of a point. However there is still 30inches of cutting awesomeness.
Blade length - 30"
Width at shoulders - 2.3"
Tang - 6"
Weight - 1lb. 4oz.
Cost - $500, please inquire if you would be interested in basic fittings.
The BOTTOM blade is forged from W2, and is actually darn near perfect. there is a small area in the middle of the fuller that has the texture of decarb. slightly mucking up the finish.
Blade length - 30.25"
Width at shoulders - 2.2"
Tang - 5.5"
Weight - 1lb. 4oz.
Cost - $575, please inquire if you would be interested in basic fittings.
Please get in touch if you have any questions or need additional pictures.
Also $75 per blade will be donated straight to myArmoury.
Flaw on Top blade
Tip of Top blade [ Download ]
Tip of Bottom blade [ Download ]
