Here is that Topic thread for context with pics of the Partisan:
http://www.myArmoury.com/talk/viewtopic.php?t=16789&start=90
Here are some early pics of the blade where you can see the strong central rib that extends into the tang at full thickness giving it maximum strenght even if it is narrow.
The fullers are ground as flats surfaces rather than just being an arc defined by the diameter of a grinding wheel and the blade is forged as opposed to ground from stock.
The mid rib is a air under 3/8" thick by the way.
