This is my latest sword (and scabbard), now just to explain, I don't makes swords full time, like Patrick Barta or Peter Johnsson, in fact most of the commissions I've done, have been through word of mouth or within my own re-enactment group. We had an invite to the Stoke museum displaying the Staffordshire Anglo Saxon hoard and I urgently needed a 6th 7th C sword so I quickly 'knocked one up'. It is loosely based on Patrick Barta's "Bildso" replica, although without the pommel deign. I didn't have time to carve the wax for casting or chip carve the bronze.
The sandwich 'filling' in the crossguards is Whale tooth, which a friend gave me, it had been sat in their garden for a couple of years then in a box in the attic.
The 'Dummy' rivet heads on the tops and bottoms of the guards are steel, fashioned to shape in my drill, held in a vice like a basic lathe. then a four inch nail is peened through at both ends and ground and polished.
The cross guard sandwich plates are brass, separate plates of concentric oval/leaf shapes.
I normally make the blades my self from EN45 spring steel, but I was out of stock and in a rush so I re used an old blade I had kicking around. Not quite as wide a blade as I would have liked for this period, but it is acceptable.
The scabbard is thin leather over wood, with 'cording' done with Gas welding rod, set into grooves cut into the scabbard.
The 'slider' is of the same design as the Valsgarde 7 one, however, it is carved from Indian water Buffalo horn. Yes, I know they weren't too common in Anglo Saxon England in the 6th or 7th C but, it could have been imported.
The Baldric I made myself, with the 3 way suspension carved from 6mm Brass plate in A Vendel design, the same design is used for the strap end, The buckle is one by Dave Roper, a Finglesham replica. the lower scabbard buckle is an experiment in faux cloisonne using that Polyglass resin with a red dye to look like Garnet. The buckle itself is not cast, just carved from 6mm Brass plate.
I know the finish could of been a bit neater, but I have neither the space, equipment or patience to do a better job. This I hope will change eventually!
Bruce
