Posts: 369 Location: Sweden
Tue 30 Oct, 2007 6:52 am
Thanks for the pic Sean (never too late) and the comments..
Here are some more pictures and the first one in higher resolution;
http://i124.photobucket.com/albums/p19/De-Pro...piess2.jpg
http://i124.photobucket.com/albums/p19/De-Pro...piess3.jpg
http://i124.photobucket.com/albums/p19/De-Pro...piess1.jpg
I dont think 'Awl-pike' is a very good translation, since its obviously an infantery spear of quite avarage length, not to be use in a phalanx-formation but as a spear exclusivly dedicated for thrusting to combat armoured opponents.
The one i made is ca 230cm long and weighs 1,8kg, its balance is 15cm down from the rondel which gives it a good balance when held with two hands in say a low guard, with still some weight forward for the thurst.
The spear i made i wanted to fit a simple soldier, a munitions-grade weapon. So i gave myself a timelimit, four days, to do it in, to try and get some of these imperfections that you have a hard time accepting if you work it merely as a peice of art, but that i think are important to approach the feel of the time. So its not a forging-masterpeice but im pleased with the resault.
Its made fully by hand exept the basic sledging done with spring-hammer. Tool-steel 0,6%carb, hardened, tempered and handground.
The shaft is Red-beech, a type of wood found where these weapons where made originally.
