On a medieval history board I frequent, a member was talking about a "Celtic Rapier" type weapon that I'd never heard of. Here's his reference for it (as well as a rough picture).
| Quote: |
| The really odd-ball Celtic sword is known as the "Rapier" style. It account for maybe 1% of Celtic swords, but it shows up in the early LaTene era, has the length and profile of a traditional Renaissance rapier, but had a triangular cross section.
What follows I've transcribed from "The Celtic Sword" by Radomir Pleiner pp 69-70 (forthcoming illustration from p14 (fig. 2)) "We should note finally a curious type of sword, the long rapier known in German archaeological literature as the Knollenknaufschwert. Fewer than 20 examples from some 15 localities in central Gaul and southern Germany have been recorded. They come in the main from wet sites, so that for a long time their dating was in doubt, until Kramer (1962) in his analysis of the Chiemsee find, brought out a consensus opinion that this type was a Celtic weapon of the Late Hallstatt or Early LaTene periods. What is striking about these weapons is that they are exclusively thrusting weapons, a fact completely at variance with the concept of the Celtic cutting sword. It is also most noticeable that these weapons are totally unknown from the usual cemeteries and hoards. There technical characteristics are of interest also. The type has a square-shaped section, and is narrow (tapering from 18-25mm at the guard to about 12mm at the point) and extremely long in length (73-83cm). If we include the hilt-tang, then the length rises to 86-105cm. From X-radiography carried out by Driehaus (in Kramer 1962, 121-4, pl 11), the blade (at least in the case of the Chiemsee specimen) was welded together from two triangular-sectioned iron bars. The hilt-tang was not formed on short bars of lozenge-shaped section to the campaniform arch at the top of the blade to tang. The top of the hilt where the pommel sat was perforated centrally. The most characteristic feature is the iron beads or globules attached to the welded-on hilt-tang, with four located at the pommel and two on the tips of the guard, crowning the hilt. The scabbards found with these rapiers are constructed from two overlapping iron strips, and they fit closely to the blade surface. It was mounted by a hinged joint to an iron plate locked by a removeable iron pin. These look very much like very good examples of the work of the locksmith. It is hard to see how the plate was ever suspended to a normal belt, or even how it could have been hung immobile on pillars, walls, or trees, and further discussion would merely be highly speculative. We may hazard the guess that this weapon, which was clearly suitable for fencing only, was used in duels of exceptional, even ceremonial or ritual importance, and was never worn to battle. Thus it did not form a part of the normal equipment of a warrior." |
Has anyone here ever heard of such a weapon and where it may have been used?
Jamie Fellrath
ARMA-Columbus
