Posts: 361 Location: Haifa, Israel
Fri 27 Feb, 2009 5:42 am
My new Archer's Sword
Posts: 864 Location: Michigan, USA
Fri 27 Feb, 2009 6:44 am
Hiya Sa'ar, this is a nice, simple package, congratulations. Some questions though : Did you make
the pommel ? and fashion the adjustments -- to the hilt and I'll assume the grip as well -- yourself ?
or was there another party involved ? And did the parts originally come from different companies ?
What were your thoughts and hopes for the design ? Did they match up pretty well to the result ?
Fri 27 Feb, 2009 10:02 am
Thanks Matthew. Although I can do basic metal & wood works, good fit & finish are beyond my grasp. I have a fellow knifemaker, a sort of "Jack of All Trades" man - the right person for such tasks. I sat with him in 2-3 phases of the work, to check the balance and - we put different lead weights on the tip of the tang to get it done, with and without the other parts. The blade & sheath are Windlass, the guard may be Windlass two but it came from another person. Grip, binding and pommel were made locally. Once I check the dynamics of the assembled sword it was ready for final sealing with epoxy.
The dark reddish-brown lace was actually a suggestion of the maker - I wanted a red lace. I like it better the way it came out because it gives you the impression of a used item, with the grip dark from sweaty hands and fresh patina develop on the metal parts.
Fri 27 Feb, 2009 11:28 am
Nice little sword. If you don't mind me asking, what windlass model is the blade from?
Fri 27 Feb, 2009 11:45 am
Jason Mather wrote: |
Nice little sword. If you don't mind me asking, what windlass model is the blade from? |
I think it's the Coustille. The blade had been left unaltered; while we had to file off a little the throat of the sheath in order it will accomodate the new guard snugly.
Posts: 1,435 Location: California, Maryland, USA
Fri 27 Feb, 2009 4:39 pm
I was considering picking up a stock Coustelle...how is that blade for you?
M.
Sat 28 Feb, 2009 8:41 am
I don't know how the Coustille handle as a complete sword. The blade itself is ground pretty nice and has pleasant lines. It is "half sharp" as all Windlass blades I've seen so far (alas, not so many :\ ), meaning it will not cut you if you run your finger on it, but it will cause damage if you strike with.usuallyy the complaints agains Windlass concern the hilts & sheaths, not the blades. The tang is pretty thick and is integral part of the blade.
Posts: 967 Location: Michigan
Sat 28 Feb, 2009 9:13 am
Looks like a fun little weapon Sa'ar, congrats!
I think I recognize that cross too ;)
Dan
Sat 28 Feb, 2009 9:45 am
Indeed Dan, indeed.
I thought to use your pommel alltogather, but it is much too heavy for this sort of blade. It awaits a future project now. :D
Posts: 1,606 Location: Chicago, Illinois
Sat 28 Feb, 2009 10:30 am
Nice little sword you put together. I especially like the grip. Sounds like it was a fun project with satisfying results!
Sat 28 Feb, 2009 3:12 pm
Tim Lison wrote: |
Nice little sword you put together. I especially like the grip. Sounds like it was a fun project with satisfying results! |
Thank you Tim. I was a little worried how it would come up in the end but I'm very happy with the final result.
I can post another project of former time if there is an interest.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
