Posts: 6 Location: here and there
Sun 21 Dec, 2008 3:28 pm
What is this??
Hello all,
Was hoping someone could tell what this is more specifically, all I know is that the blade is Jade inlayed with bronze and the handle appears to either be white jade or a type or marble, the carvings on the handle are similar to those seen on some Jians.
11 inch blade 1 ft 3.5 Inches overall. any tips on what it is and age would be greatly appreciated.
Posts: 1,265 Location: Malaysia
Tue 23 Dec, 2008 9:02 pm
What is this??
Pat,
I think the weapon you are holding is actually a dagger but it looks more like a miniature form of a jade-bladed Jian.
Posts: 75 Location: NJ
Tue 23 Dec, 2008 9:12 pm
Looks more like oxidized copper/bronze then Jade...
Posts: 361 Location: Haifa, Israel
Wed 24 Dec, 2008 5:08 am
Chinese Jian type object with a jade hilt and a copper-alloy blade. Most likely a repro.
Posts: 1,435 Location: California, Maryland, USA
Wed 24 Dec, 2008 2:03 pm
It's quite pretty, even if it's a likely repro. I doubt it's jade, though. It should be pretty obvious if it's metal or stone if you're holding it up close like that, however. What's the weight of the item?
M.
Wed 24 Dec, 2008 3:42 pm
Oh, I have no doubt its stone, I did a magnetic test, Ive scratched it , and I used a mild solvent to test to see if the green was verdigris and its not its stone, Blade is likely to be Nephrite which is documented to have color ranges of Deep greens to yellows and whites as well as having deep greens with some irregular coloration in it as well. Id guess weight to be near a pound or so with 95% of the weight being centered in the handle.
my Girlfriend got it on Ebay from a oriental " antiques" dealer there also appears to be solidified sediment, possibly being a light yellowish silt or a light brown sand around where the blade joins the handle.
this is just what I have been able to determine so far, Im mainly interested in its use in chinese culture and prospective age. Even if its a repro Id like to know the same info of what its modeled after and history of the item.
Posts: 123 Location: Sweden
Sat 27 Dec, 2008 12:12 pm
Does nephrite really get that many different colours next to each other? Especially that strong and clear ones, with no white regions between them.
Sat 27 Dec, 2008 1:20 pm
From what Ive read it can... but thats only from what Ive found, I dont know the reputability of the page
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
