Posts: 411 Location: Madison, WI
Tue 23 Dec, 2008 3:15 pm
New Sword, Type XIV/XXI
Here is a sword that I just finished up and wanted to share with everyone. For this piece I wanted to play with the general blade design of the XIV.6 and XXI.1 from Medieval Records. The both blades jumped out at me when I first flipped through the book and I have been playing around with how I wanted to interpret this design, and what kind of handling characteristics I wanted each to have. I have to say that the end result is some what of a bastard child that the two would have produced. I forged out a blank from L6 and ground it more to the shape of the Type XXI except I didn’t get the width that I was aiming for. I decided to carry on and finish the blade anyway since I didn’t want to waist the steel and I wanted to follow through the entire process see what factors of making this blade would require attention or might prove problematic. I decided to use three different radiuses for the fullers to get the required fuller depth, 4 inch from the base up to about 10 inches up, then a smooth transition to a 2 inch fuller that goes up to about 22 inches, then finished off with a 9/16 wheel. After that there was a lot of hand rubbing to get all those transition lines to blend away. I then had the joy of realizing that grinding the edge without hitting the ridge line was a sort of joy, or pain, or huge pain.
I took a blend of the two swords guards, and once again used a proportion equation to try to get an initial sense of what size my guard should be to fit the aesthetic proportions of the XIV.6. When
Oakeshott said “It’s a big sword” he was not kidding. I forged out a blank and started to clean it up on the grinder and I really had to drop the proportioned dimensions so that everything would balance out. I decided to modify the lines of the original and add more curve, which is a characteristic of the XXI.1, however I still think there is a clear relation between the two guards. For the pommel I decided to also make 10 surface facets, however I made the center indent larger from the original.
I decided to experiment with doing some nice risers on the handle, I think it turned out really well, all though not being 100% historical. If someone is interested in this blade but wants the grip to be stripped and regripped plain, it can be arranged.
I had a lot of fun making this blade, despite all the challenges that it decided to throw my way. I will be attempting a full sized version of both these blade when time allows, but that is for another day. I am asking $1500 plus shipping for this piece. Here are some stats.
Overall: 36 3/4”
Blade: 30 3/4”
Fuller length: 27 3/4”
Width at guard: 2”
Width 2” from tip: < 3/4”
Weight: 2.1 lb
CoP: 20” from guard
Balancing Point: 4 1/2” from guard
Here are some pictures, enjoy!
Attachment: 144.46 KB
Hilt
Attachment: 136.16 KB
Pommel
Attachment: 121.04 KB
overall [ Download ]
Attachment: 132.45 KB
Grip front [ Download ]
Attachment: 147.49 KB
Grip side [ Download ]
