OlliN was approached by myArmoury member Jean Thibodeau about starting a custom shop project he had been thinking about for awhile. We are very excited to be working with Jean on his project. He thought it might be of interest to the forum if we post our production of his custom sword. I thought that was a great idea. To get things started, below is Jean’s original email and the photo he sent to us that we are using to start up the design process.
Jean’s Comments
“Here is my idea at the moment based on the Pontirolo and on the SOSM with a different pommel. The grid is 1" per square so the blade would be 3" wide at the base and 40" long approximately. I would like a fairly thick blade at the guard and distal tapering to no less than 3 mm near the point ( estimate at the moment ) and maybe 5 mm at its thickest: This would be much to heavy with an elliptical grind but might be O.K. with a hollow grind. This is just the railroad engineered starting point. Total weight shouldn't be greater than 5 pounds and the POB should be close to 6" and no more than the 9" of the Pontirolo, but at the weight of 5 pounds a lower POB than 9" would be better. Let me know what you think and if my numbers about weight and dimensions are realistic. Oh, the Pommel is of the very fat Brazilnut close to the Tea cosy type I think or one of the somewhat " Lumpy type ". At this scale the pommel is quite large at 3" across and weight can be adjusted by making it fatter or thinner. The grip should be about 4.5" long, grip thickness to be adjusted/ determined. Any extras ? maybe some lines on the pommel and / or guard i.e. light file work and maybe a few letters or symbols in the fuller. (Simple and sober. Fantasy or historical?).”
We don’t always get such a detailed email for custom shop orders (which is always fine). It was great to get such specifics right of the bat!
Where we are at at the moment is working on sketching out a full size rendering of what Jean has requested. Mark and I are going over the specifics and will be working with Jean through this process. Jean has been a saint right now, because we have been swamped with finishing up a couple of other pieces at the moment. We’re hoping to be sketching here shortly. As we do, look for more posts and pictures of this project during it’s creation.
Best,
Matt
