I'm not sure whether this belongs here or in Historical arms talk, apologies in advance to the admins if it's misplaced.
I have the good fortune to have just filtered up to the top of a maker's waiting list and have been discussing a type XVIIIb longsword with him.
I'm not going for a recreation of a specific sword, so far my criteria are fishtail pommel and hollow ground. I have been looking at a lot of pictures both of reproductions and period swords to get ideas for what elements I like and don't like prior to discussion with the maker about what elements go together while being accurate to medieval weapons.
Something I really like the aesthetic effect of is the very long narrow grip on the well known XVIIIb in the Bayerisches Nationalmuseum in Munich, and the Albion Munich inspired by that sword. Aesthetically I find them much more attractive than the more straight-sided grips found on swords like Albion's Regent and Earl for example.
I've got a couple of questions about long thin grips like that; firstly, are they appropriate for the 1460s-1470s? There's something about them that says "early 16th century" to me, but I can't rationalise that and I don't have the expertise or the library to know whether they are appropriate for my chosen period or not.
Secondly, I'm not sure about is the usefulness of such a thin grip to someone with quite large hands. Can anyone comment on what they're like to handle?
Many thanks.
Many years ago when I was switching my training tool from a katana to a longsword, the longsword's relatively thin grip had caused me a lot of troubles. Back then I didn't understand why the grip had to be so thin. I had to apply a lot more gripping power on the longsword than when wielding the katana. I ended up padding up the longsword grip and made it as thick as a katana's grip, or wearing gloves with some padding. Later on I realized that the thin grip was necessary for the ever-changing gripping method in longsword techniques and it became more natural to me.
So I would say large hands with thin grip, yes, there could be problems but it can be overcome.
I try to approach handling any sword or knife with an open mind. There are visual appeals and there are tactile differences that are often two very different things. I have not handled the Albion in question but do own a Del Tin 5157 and have come to really appreciate the handling/steerage, despite a lower level of blade engineering (mostly distal taper). This particular sword has no end of reference for one's fingers and with a thumb to the flat, edge orientation and point control are quite good. I have fairly large hands and wear a size 14 glove.
Although the profile appearance of the Albion grip may seem very svelt, I have to imagine it is not just a tapered and round form. Thus there is going to be the same types of tactile reference between the flat and edge orientation. if switching immediately between different swords (say the three on this table), there is often a sense of disproportion and perhaps some akwardness. Of the three below, the Del Tin is the lightest and longest but the weight isn't the only factor I found immediately user friendly, despite a much samller grip in crossection.
GC
GC
I'm not sure about 1460s/1470s. I associate that grip (shape and proportion) with German swords of ca. 1500 (as a midpoint--art shows them later and earlier). Dürer shows them in late 15th, early 16th c. An illustration of Maximilian from Der Weisskönig shows one similar to the Bayerisches example (Albion Munich/A&A Dürer). At least one Dürer illustration shows an embossed scabbard like that of the B. XVVIII, and that woodcut is ca. 1510 if I remember correctly.
I have one of these on my workbench right now. In fact, I'm in the process of choosing a grip so I'll be interested to read the responses of others.
For what it's worth, I consider my sword--a slightly battered A&A Dürer--to be 1480-1520 and I'm going to give it one of these grips--flared lower portion, very slender top, "rain" guard. Haven't decided between oval or faceted lower section.
Al Muckart wrote: |
Secondly, I'm not sure about is the usefulness of such a thin grip to someone with quite large hands. Can anyone comment on what they're like to handle? Many thanks. |
The length of the Munich grip gives the fencer a lot of leverage. I have very average sized adult male hands (some Large gloves fit too tight, some are o.k.) I was stunned at the speed and precision the Munich grip afforded. Seriously, it is scary initially. I have not tried it with armoured gloves.
P. Johnson corresponded some while I was waiting on the delivery. There are some unusual features (method of guilding, style of build, specific pilgrimage coin in the recess) which he seemed to speculate paired the Bayerisches sword with others by a similar maker, and could indicate an earlier date (mid 15th century, rather than late 15th or 16th century.) I would say that if someone researched the exact coin carefully, the issue could be argued.
Jared Smith wrote: |
The length of the Munich grip gives the fencer a lot of leverage. I have very average sized adult male hands (some Large gloves fit too tight, some are o.k.) I was stunned at the speed and precision the Munich grip afforded. Seriously, it is scary initially. I have not tried it with armoured gloves. |
Hi Jared,
Do you have any idea what it is like to swing such a long-gripped sword from horseback? Would the long grip cause interference with wrist and forearm movement?
Jared Smith wrote: | ||
The length of the Munich grip gives the fencer a lot of leverage. I have very average sized adult male hands (some Large gloves fit too tight, some are o.k.) I was stunned at the speed and precision the Munich grip afforded. Seriously, it is scary initially. I have not tried it with armoured gloves. P. Johnson corresponded some while I was waiting on the delivery. There are some unusual features (method of guilding, style of build, specific pilgrimage coin in the recess) which he seemed to speculate paired the Bayerisches sword with others by a similar maker, and could indicate an earlier date (mid 15th century, rather than late 15th or 16th century.) I would say that if someone researched the exact coin carefully, the issue could be argued. |
Hello Jared!
I saw your post and thought that I may have given you confusing or conflicting facts.
I do believe the long gripped sword in Munich should be dated to the late 15th C. Very late 15th C, like the last decade or so. I am still working to dig up more information on this sword and others that may be related to it. It belongs to a fascinating family of splendid weapons.
Long grips per se, are seen earlier in the century. There are many cases where a dating of long gripped XVIIIb and XVIIIc swords would sit comfortably in the middle of the century or perhaps even earlier.
Those swords that the Munich is such a splendid representation of seems to belong to the late 15th C and early 16th C however.
There are a number of swords in collections around Europe that shares some specific features: a certain style in how the proportions come together and the style of character of the shaping of the hilt parts, that suggests a shared origin of some kind. A regional style perhaps or perhaps even in some cases a shared origin of one single workshop.
To Al:
Long slim grips are conductive in inviting a certain attitude in the swordsman. Glen and Lance have touched upon this already: you constantly change the way you hold the sword. You shift it in your hand depending on how you intend to deliver the attack. It is not about maximizing the power in a choking grip: it is about being supple and lively. A slim grip puts specific demands on ergonomics (the way you shape the grip as you make the sword to make it effective and telling). You need to shape it *just so* to get an effective "signature" for your hand to recognize. Just making the grip slim will not cut it. It is a matter of removing dead meat from where it is not needed. Oval sections can work, but hexagonal and rounded rectangular sections are also effective. You see all these being put to work in the grips of historical swords. You see contemporary attempts to duplicate this, but it is commonly the case that some essential aspects are missing or interpreted out of proportion. The result is a grip that both looks a bit off in style and also is less than optimal in the way it functions. It is all in the details: proportion and shape matters!
To Jeremiah:
I have no experience swinging a sword from horse back. Looking at the art of Dürer and others contemporary to him you see it done all the time. I do not think this is artistic license. There might be a lot of training and experience involved...
Personally, I do not find the Munich to be a very good single hand sword. It begs to be used with two hands. I am not an expert swordsman, however, so take that for what it might be worth. When you fight on foot, you need another kind of response from the weapon, than you might need when you sit on horse back. I suspect it takes different kinds of skill and techniques to deliver *effective* cuts from horseback and when fighting on foot.
Sorry if I misquoted anything Peter. I have swung the Munich one handed, and some hand and a halfs. I think this may work fine for chopping blows on horse, but have not had anyone volunteer their prized horse (the relatives' horses are in fact valuable competition horses) for test cutting experiments. Learning to do it does not seem like it would be any more awkward than the initial introduction to stances like Ox/ Ochs, or cuts like zwerchau.
I started looking at Craig Peter's photo of the hilt and tried to remember if you mentioned something about Mary holding the child on the coin? If my reproduction Munich pommel recess is close to the actual sword's recess, there are just a few coins (no Vetons I am aware of or Papal Jubilee mediallions, infrequent at this point, either) that are similar. A Virgin Mary with child motive in a roughly oval center coin of this size could be Hapsburg dynasty mints (Hamburg 1497 gold Ducat, Ferdinand I mints occurring between 1520 and 1550 at the very latest.) A silver coin with gold fire gilding over it, corresponding to one of the Ferdinand I mints would be interesting if it could be proven. I am not a qualified expert for that kind of matter. I do share a passion for wanting to know more of the providence of the sword though. Any close up photo of the actual coin would be appreciated.
Jared
Jared
Jeremiah Swanger wrote: | ||
Hi Jared, Do you have any idea what it is like to swing such a long-gripped sword from horseback? Would the long grip cause interference with wrist and forearm movement? |
Hello Jeremiah!
Here there is a woodcut of the Tehuerdank knight wielding a longsword from horseback.
In Maximilian´s Triumphs there are plenty of men-at-arms with such type of swords hanging from their belts. I don´t think that they would carry any useless horseback weapon...
Even, in Goliath treatise, there are several armored mounted longsword techniques, and they are pretty effective, not outdated at all (Since Goliath is from XVI century), like parrying a lance with the sword and such.
I started looking at Craig Peter's photo of the hilt and tried to remember if you mentioned something about Mary holding the child on the coin? If my reproduction Munich pommel recess is close to the actual sword's recess, there are just a few coins (no Vetons I am aware of or Papal Jubilee mediallions, infrequent at this point, either) that are similar. A Virgin Mary with child motive in a roughly oval center coin of this size could be Hapsburg dynasty mints (Hamburg 1497 gold Ducat, Ferdinand I mints occurring between 1520 and 1550 at the very latest.) A silver coin with gold fire gilding over it, corresponding to one of the Ferdinand I mints would be interesting if it could be proven. I am not a qualified expert for that kind of matter. I do share a passion for wanting to know more of the providence of the sword though. Any close up photo of the actual coin would be appreciated. Jared |
Jared, I do´t think the medallion is a minted coin. Rather I think it is a unique artwork. To me it gave the impression of engraved copper with some black component filling the cuts. Enamel? Niello? I don´t know.
The medallion was on the *back side* of the sword. The empty face most probably used to house a relic secured behind a disc of crystal or glass.
I just wonder what the relic might have been? It was plundered and the pommel left empty. Perhaps it was a particularly valuable relic? A splinter from the True Cross? Some bloodied piece of clothing from a martyr?
The sword calls out to God´s Mother, so that might be a clue to the significance of the relic.
Hi all,
Thank you for your replies and your insights. I know next to nothing about period fencing but the points about being able to move your hands on the grip make sense. I will think more about what I want in this sword, but most of all I want it to be accurate to it's period. If Munich-like grips are pretty, well I might just have to get a different sword with one of those grips (after my lovely wife has recovered from me getting this one, that is) :D
Whenever it is done I will post pictures here.
Peter: Thanks for the information about the subtleties of grip shape and about the Bayerisches sword's inset pommel disc. Having never seen a detailed photo of that disc, I assumed it was done in low relief-- repoussé, cast or stamped. It's interesting to hear that it's engraved and filled.
I'm debating adding such an ornament to my own XVIII longsword project. I've researched images of saints from German and Austrian painting of the period and come up with a sketch for an appropriate design. My son is named Ambrose (nine months tommorow!) so St. Ambrose, with his distinctive open book, is my thematic focus.
I'm certainly more comfortable with engraving than repoussé, so I'm encouraged to go ahead with this part of the project. But I want to stay within historical parameters as much as possible. Do you think a saintly image is historically appropriate? Do you think all such ornaments would have been covered with glass/crystal? That would seem unnecessary except in the case of holy relics.
