Go to page 1, 2  Next
Prototype of the Henry V Sword
OK, everything has been finalized and paperwork signed with the Reinhardt Estate. We will be able to move forward with still producing the Hank Reinhardt Collection. So without further ado... Here is the proto-type of the Henry V sword from Generation 2.
First shipment should be here in June.
Here is the Copy and the stats, then followed by some teaser pictures:
Henry V Sword - Original: Dates before 1422. Westminster Abbey, England. Type XVIII, Pommel-type: J.1 Cross-style: 9
This sword probably hung above the chantry of King Henry V until it either fell, or was taken down and stowed away in an old chest in a room in the S. Triforium.
Henry V, British monarch of the early 15th century, was not just a ruler but an accomplished warrior who began fighting as early as age fourteen, when he fought the Welsh forces of Owain Glyndwr. Throughout his life, Henry V fought in many battles, including against the French in the 100 Years War. It is no wonder then that he would have chosen such a practical, no-nonsense weapon.
Ewart Oakeshott described this sword as "one of the most beautiful medieval swords to handle I have ever known." He also stated " In 1951 I spent a good deal of time with it."
We (Generation 2) has replicated this sword from a drawing given to us by Hank Reinhardt before his death. He have painstakingly recreated this sword according to his specifications.
Hank requested that the sword have the hollow pommel and that the blade be hollow-ground just like the original. He also said to try to come as near 2 lb.. which is what the original weighs.
Ours came in at 2 lb.. 13 oz., a little heavier. But here is where it is heavier. We are not capable of casting a hollow pommel, which certainly would have been lighter than our hollow pommel. I do not mind explaining how we made our pommel, so that you can judge for yourself the time we put into making this replica sword.
We started with 1/8" plate steel and made the circular band. Then we took two more 1/8" thick plate and made the front and back of the pommel, welded them together, ground and polished it smooth. I do believe this is where our extra weight comes from.
This sword does exemplifies attributes of a knightly sword of the highest quality . It has superb balance making it an exceptional fighting sword and excellent control of point for thrusting.
Blade length: 27 1/2"
Handle/Hilt length: 6 1/4"
Grip Length: 3 3/4"
Overall: 34 1/2"
quillon Length (Across): 8"
Point of Balance: 3 1/2" Below Hilt
Weight: 2 lb. 13 oz.
Comments please........
 Attachment: 53.62 KB
 Attachment: 35.15 KB
 Attachment: 63.85 KB
Is that a hollow ground blade I see there? I really like this one. I'd have to say that in my opinion this is the best looking sword you've all produced to date. The only complaint I'd have is the guard. It seems a little to wide for the type, although I'm no expert by a long shot. Could the guard be made thinner or would that be a price point issue? Speaking of price point, what will this sword be going for? All in all I really like this one and would definitely consider adding it to my collection.
Yes it is a hollow ground blade like the original. On the quillons (guard) we went off Hank's specs. I do not know what the original width of the guard is.
The Price is $279.00
Clyde,
This looks really nice. Very tempting. The pommel looks pretty good and I'm glad it's at least partially hollow. The shaping of the pommel looks a little different from the original and the recess doesn't look as deep. It would also be nice if the terminals on the guard were curled under (like the original) rather than clubbed. Those are relatively minor quibbles.
That said, I've owned a reproduction of this sword that was a few hundred dollars more expensive (with no scabbard or hollow grinding) and yours looks pretty darn good and is much cheaper. I think yours is a competitive offering. A few tweaks and it might become a must-have for even more people.
Here's the original for reference:
For that price, it looks like this will be a very competitive offering. I must say, this is the best looking sword you guys have turned out to date! There are some aesthetic things I could nitpick about, but considering this is under $300, if it handles well and is well made, I can live with that. Looking forward to seeing one of these.
Henry V sword.
That is a very nice looking sword ! It is also one that I would certainly consider buying myself when it becomes available. My only question, and forgive my ignorance for this, is it a sharp blade ? I would want it for display, so blunted reenactment weapons are not of use or interest to me unfortunately.
Nice sword ! :) I look forward to hearing more about it.
Russ
I might have to get this for myself. It doesn't fit into my recent move to keep my collection viking, but its a really good price.
Thank you all!
And Mr. Russ Thomas, yes it does come sharpened.
It should be available in late June.
Again thanks,
On looks alone, this is without a doubt the best sword in the Gen 2 line. And if the sword handles as good as it looks then I think you're going to be hard pressed to find a better reproduction anywhere at the same price point. While there are a few minor details that people could nitpick about, at around $300 it really isn't worth it. Simply outstanding.
This very well might be my first Euro sword! Unless it's sold out by the time I save up :eek:
I agree, this is definitely he most gorgeous sword I've seen out of Gen 2, even more so than the Witham and Irish, which is saying something! If it performs half as good as it looks, it will be well worth the price and THEN some.
Congratulations on a home run, Mr. Hollis!!
Brilliant sword, the hollow grind looks very good Ill have to keep an eye out for this one. The Henry V sword is the first medieval sword I can ever recall seeing as a kid so I've always wanted to own a replica of it some time. This might be the one.
Top marks to Gen 2, game upped by about 500% I think! :cool:
looking forward to seeing what else is in the pipline.
Well done, guys! A fitting tribute to HR.
The guard doesn't seems thin to me and I personally like guards to be strong as long as they don't get chunky by overdoing it.
The ends being clubbed rather than curled under is a very minor detail I think: Probably more historically correct but they seem " plausable " to me in period ( could be wrong ? But I like the look anyway. ;) :D )
The price makes it almost impossible to resist. :D :cool: And if the steel is as good as my Dordogne sword I know that it is also a quality using sword, so it should really inspire confidence in being able to survive normal use and borderline abuse like the accidental hitting of a nail with my Dordogne leaving only a tiny dent that disappeared after a light recharpening.
Just a FYI - We will include a 11"x17" drawing of the sword, but since Hank passed away before seeing it, there will be no signature on this drawing, as with the Dordogne and Witham swords.
But Hank did want copies of the drawings to be included with each sword. Just a little extra something.
I've already asked Ryan at Kult of Athena about availability and to let me know when he thinks he will have them in stock.
( obviously after June when they are supposed to be ready for sale ).
Oh, also asked him about the riding sword. ;) :D I haven't made the purchases official yet but the odds are high that I will get both.
Hmmm, part of that upcoming economic stimulus payout might just be spent on one of these. I wish though that I could handle it first before laying down the money.
Here is a review done on one of the 2 proto-types that came in. Review was done by Mike Harris andother review will be done later by Adam Sharp.
Next shipment is in June.
http://sbgswordforum.proboards70.com/index.cg...hread=4589
Clyde
Clyde
Nice review, though I do wish people wouldn't steal myArmoury's images (the photo of the original sword they used is on a background unique to swords in our feature articles). :)
So this is an Oakeshott Type XVIII sword? I am still working on learning the system.
Yes sir, it is very close in that style.
Page 1 of 2
