I'm looking into commisioning a migration period spartha, pattern welded, and Patrick Barta is my favourite for the task.
What I'm seeking is any information on any swords from the Valsgarde inhumations, please can anyone help?Cheers
Hey David...
You have fine taste in swords and swordmakers.
Here are some pictures I found of Valsgarde Swords.
ks
Attachment: 86.69 KB
Attachment: 97.72 KB
Attachment: 86.18 KB
Attachment: 97.78 KB
Attachment: 99.22 KB
Attachment: 87.07 KB
ks
Cheers Kirk, the swords are all equally beautiful !! The sword I'm after in particular are the (two swords) approximate to the Valsgarde 7 inhumation. One I understand is a ring pommel the other not.Would you know which of the images these would be? Where did you source the images? In my own (humble ) opinion Patrick is a master of his craft and his pattern welding second to none, pure art.
David Huggins wrote: |
...The sword I'm after in particular are the (two swords) approximate to the Valsgarde 7 inhumation. One I understand is a ring pommel the other not.Would you know which of the images these would be? Where did you source the images?.... |
Hi David...
Sorry on the source info... I have had those images for a long time... I think that they came of the internet with no source info... However if someone knows which work these images came from please let me know so I can source them and hopefully find more data.
If you put the cursor over the image it should show the picture file name, any info I have will be included in that. The third and forth sword I posted indicate grave 7.
take care
and welcome to the forum... it's good to have you here! :D
ks
Thank you once again Kirk, much appreciated. An other member off-line has kindly offered further resources.
I love this :D forum!!
Best regards
Dave
Best regards
Dave
I'm looking for further information on the Valsgärde 6 sword.
Does anyone know if it was found along with a scabbard?
I've found some pics of the hilt (these here are great too!) but not much info about it... what's the material? is the pommel hollow? what's it's weight? dimensions?
Also, what's the overall lenght and widht of the blade?
Too many questions =$
Still... any information will be of use =)
Andres M. Chesini Remic wrote: |
Does anyone know if it was found along with a scabbard? I've found some pics of the hilt (these here are great too!) but not much info about it... what's the material? is the pommel hollow? what's it's weight? dimensions? Also, what's the overall lenght and widht of the blade? Too many questions =$ Still... any information will be of use =) |
Which sword from Valsgarde 6 were you referring to? Two were found. Both had traces of scabbards adhering to them, but I don't believe there was anything reconstructable. Here are the stats for both swords, per my partial translation of the Weapons chapter of Arwidsson's book:
Sword I
Dimensions: Length 94 cm. Blade Length: 78 cm. Blade Width: 4.8 cm. Greatest Thickness: ~0.7 cm, Length of the Grip: 9.8 cm. Width of the tang: 2.6-1.8 cm, measured on the upper side of the lower guard and on the underside of the upper guard. The upper guard 10.8x1.7x2.5 cm, the lower guard 12x1.5x2.8 cm. Width of the scabbard at the top is ca. 5 cm, greatest thickness of the scabbard ca. 2 cm. Thickness of the wood 2-2.5 mm
Sword II
Dimensions. Present length of the sword is 89.5 cm. Blade length is 76 cm, and width is 5.5 cm. The grip is 9.6 cm long and nach unten zu 3.2 cm wide. The thickness of the lower guard is ca. 2.2 cm. The scabbard is nach oben ca. 6.4 cm wide, and the wood thickness is 2-2.5 mm.
(Sorry for the left over bits of German in the text - as I said, it was a partial, unfinished translation. Guess I'd better get cracking and finish it!)
I'm interested on both swords.
Don't worry about the german, I understand it, and this was really useful to me! =)
Hey guys great to see some interest in migration period swords, as they dont get much attention online. I'm already on Mr. Barta's waiting list but haven't yet decided on which sword I would like but one of the Valsgarde swords is in the top three. best of luck with your order, I'm sure Patrick will make something worthy of a king
Such a coincidence!
I mailed Patrick a few days ago, asking him if he has done, or is going to do any valsgarde sword. He replied that he was just about to do it, because of the increasing demand on it =)
Back on the topic:
I browsed sweden's museum of history's archive for a couple of hours, and I didn't find anything on valsgarde helmets or swords.- A pity...
Any suggestion?
Back on the topic:
Any suggestion?
Hello
I have a Valsgarde 7 ring pommel sword and scabbard on order with Patrick,. Not sure where I am in his waiting list though, but know it will be well worth the wait. Having handled Paul Mortimer's Sutton Hoo spatha, a sword of high art and beauty made by Patrick, I am greatly looking forward to seeing the V7 sword on completion.
best
Dave
best
Dave
Here are some picture of a beautiful ringhilt from Gr. 8 at Valsgarde. There even seems to be some of the carving on the wooded scabbard core preserved.
take care
ks
Attachment: 146.96 KB
Attachment: 148.02 KB
Attachment: 148.92 KB
Attachment: 148.56 KB
take care
ks
Laurent Bemtgen wrote: |
Hello, I just wanted to know if there have been swords found in Grave Nr.5 and Nr.8 ? It's hard to find Infos in the internet and I still had no possibility to get G. Arwidssons books.
Curiously, the Valsgarde 5 grave has never been published. It was *supposed* to have been - the Valsgarde 7 book, published in the late 1970's, states that Par Olson was going to write it, but to my knowledge it never saw the light of day, nor do I have any idea what became of the material that would have comprised it or who presently posseses it. My suspicion, given that Par also wrote "Die Saxe von Valsgarde I" in the 1940's, is that he may simply have passed away, leaving publication of Valsgarde 5 in limbo.
Too bad, as the Valsgarde 5 helmet is an important artifact - pity someone in Sweden can't take the initiative and publish something about it.
C. Gadda wrote: | ||
Curiously, the Valsgarde 5 grave has never been published. It was *supposed* to have been - the Valsgarde 7 book, published in the late 1970's, states that Par Olson was going to write it, but to my knowledge it never saw the light of day, nor do I have any idea what became of the material that would have comprised it or who presently posseses it. My suspicion, given that Par also wrote "Die Saxe von Valsgarde I" in the 1940's, is that he may simply have passed away, leaving publication of Valsgarde 5 in limbo. Too bad, as the Valsgarde 5 helmet is an important artifact - pity someone in Sweden can't take the initiative and publish something about it. |
Well, that's a shame, for as I was really hoping to find some mor informations on the Valsgare 5 grave. But it seems as the work could not be finished. Well, hopefully someone will continue this work, because, as you say, the Valsgarde 5 Helmet really is an important an interesting artifact.
I have been told by a friend of mine who attended a scholarly seminar in Uppsala recently that they plan to translate all the Valsgarde books into English soon and print updated versions.
Valsgarde 5 has never been written -- Birgit Ahrrenius was doing it - but the work seems to have come to stop. When I asked her about it, a couple of years ago, she was very non-committal. This series of books began in 1942 - 3 books in 67 years -- possibly a record wait for volume 4! We can't expect too much!
Paul
Paul
Hurrah Paul.... :) We shall just have to be patient and await the reprints...grrrrr :!:
Hurrah Paul.... :) We shall just have to be patient and await the reprints...grrrrr :!: |
Aye I am getting some parts of the Valsgarde 8 book translated from german to latvian for my use as my german knowledge iss rather limited, but that will not be of much use to english-speaking community I fear :) So getting a proper reprint in english would be most useful.
Paul Mortimer wrote: |
Thank the gods! No more wading through the books armed with nought but a huge English/German dictionary and an ever increasing wish that I'd paid more attention to Mrs Braun at school.
I got my copy of the V8 report when I went to Upsalla. The lady on the desk at the Gustavianum was so apologetic about the V8 helmet not being on display on the day that I visited that she gave me her copy. :cool:
Matt,
You are a lucky man! I had to buy mine -- and all the other ones.
Paul
Paul
Matt,
You are a lucky man! I had to buy mine -- and all the other ones. Paul |
Lucky indeed; I got all of the rest for free too, from a very nice man with a shiny hat. ;)
Page 1 of 3
