I have examined it in hand and the knotwork carving is deep. The pommel cap is brass and appears old and worn (you can see the lines where it was soldered together and beginning to come apart). The pommel nut is recent and machined, the "ferrule" between the wood and blade I believe later too. The hilt at the haunces has what looks like 2 pins each where they were once covered by brass shoulders. Inside the hilt the hole starts rectangular and ends at the top round. Also on the knotwork - only in one place is there a place that has trace evidence of incised lines (near the blade), the rest is smooth, although it is possible that they have been worn smooth.
The blade is 11.75 inches and comes from a cut down sword of European manufacture. In some of the back notches there is black and brown rust and patina. The blade may have been cleaned in the past. On the back of the blade there is a somewhat false edge rounded (and some of the notches are also worn). The tang has black patina and a rectangular tapering shape ending in a screw. Black patina still exists on other parts of the blade as well.
Could this be an antique dirk or a reproduction? If antique, what period would you guess? Any and all feedback is welcome (please!).........
Jose
