The common concensus is that I need to diversify. So in that spirit, I've decided I need a good spear appropriate for a Norman portrayal. I've had my eye on this thrusting spear but I'm not sure if it looks too Viking. Would a winged spear be more appropriate, or a slimmer throwing spear type be more appropriate to a Norman portrayal? Any other makers anyone suggest? Arms & Armour has been mentioned to me, any others?
Eek, why is the blade brown? I'd steer clear of this one, I'm afraid. My impression is that winged spearheads are a little early for c. 1066, anyway. You'd be better off with a plain steel one, not too big, with a straight-tapered blade. Not sure where to get a good one, though, it's been too long since I shopped for one! Arms and Armor should be a good place to start, though. The world DOES need more good spears!
Good luck!
Matthew
Good luck!
Matthew
The spearhead is Hanwei's Thrusting spear; The spearhead is "pattinated brown", while the socket emulates the silver etchings found on some dark age spearheads. As silver does not rust, the museum pieces have this "half corroded" look.
Yes, it's a bit silly.
Having owned all of Hanwei's spear heads, I can vouch that this ones lugs are no thicker than a sword blade.
Just a FYI, for I found them a little too thin.
Yeah, the common advice seems to be steer clear. Well, having spent quite a bit on swords recently, I don't think I am quite in the position to buy an A&A spearhead (one day though), so does anyone have any opinions on the spear offerings from Windlass?
I can't help with the quality of the spearheads from Hanwei, but winged spearheads are definitely not too erarly for the Norman Conquest, and the Hanwei looks correct. There have been spears with side hooks in the 7th. century in central europe. From these predecessors the Franks developed the typical carolingian winged spearheads in the 8th. century, so they would have been in common use in Normandy in this period. Their use by norman warriors until the 12th. century is also confirmed by book illustrations from the period.
I agree with Felix, the winged or lugged spear head is documentable to the Norman period. However, the neillo work on the Hanweis socket really places it in an earlier time frame for me. The Hanwei spear heads are also rather shoddily cast as well. There's nothing wrong with that neccesarily, but Hanwei typically does such a terrible job of overheating and burning steel during their casting and heat treating that I'd have to call these decorative pieces. I have one of the earlier ones without the idiotic brown finish. It's nice enough to look at but certainly not a good representative example of what a spear head should be.
Patrick: So which of the Windlass offerings looks the best in your opinion?
This one looks the best to me, not perfect but workable and affordable.
http://www.kultofathena.com/product~item~1-68...r+Head.htm
If it's a bit too large it can be ground down to a more preferred size. given the cost it wouldn't be a big outlay, even if a butt cap is used as well. I don't have any problems with the A&A 12th cent. spear I already have, but I'll probably use this one when I decide to sit down and make one a bit longer.
Robin, I own the winldass generic "viking spear" and I've found it a most rewarding weapon. You can get it from $30-36 without even trying to look so it's very inexpensive. Mine costs me literally nothing because I had racked up a few $10 gift certificates from Paul Southren at www.sword-buyers-guide.com for several reviews on his forum that were placed on the main site.
I tapered a 7 foot spear shaft (and added the thrid blistetr to my thumb in a matter of a day....one from hedge trimming, one from sabre fencing [parried too hard and the blade slid out...even hurt through the glove] and finally this :lol: ) and placed the spear head on it. I believe that it accomodates a 1 1/4 inch shaft, but obviously you'll need to spend 30 minutes with a chisel tapering it. Mine fits snugly with only pressure holding it down. The only complaint I can find on it is the blade itself is just the slightest inadequate in terms of tempering. It seems that, when hit against things...(oak trees, etc. :lol: ) it gets bend just slightly out of line. But this takes litterally one second of hand presure and it's back to new.
edit: It's the one Patrick posted above!
Hi
Ive got one ( non winged version ) Its hollow? Also the silver is plated over copper, its starting to show. For that price in Australia you can get a nice but plain solid example of a authentic looking spear head.
N
N
Hi all,
Here is a lance head I'm currently working on. It was found in a river in Belgium. I have to write a conservation report on it. I don't know the typology of this type of lance head. Is there anyone on this board who knows the evolution and can give an aproximate date for this object?
And yes, this lance head measures 50cm. It's a wicked weapon :D
Thanks in advance,
Jef
Thanks in advance,
Jef
On my end, all I am getting is the dreaded red X... :cry:
Fixed it ;)
Wow! I would not want to be facing that down. Stout wooden shield or not!!! That is just brutal looking...
Sorry I can't be mmore help dating it. Don't know much about lance heads...
Jef P. wrote: |
Hi all,
Here is a lance head I'm currently working on. It was found in a river in Belgium. I have to write a conservation report on it. I don't know the typology of this type of lance head. Is there anyone on this board who knows the evolution and can give an aproximate date for this object? |
The spearhead in question is similar to Pettersen's type D. He dates them to the 10th century.
Attachment: 58 KB
Pettersen Type D [ Download ]
You're right, Elling, about Petersen, that is. Things have been a bit refined since.
I'll PM you, Jef.
Fab
I'll PM you, Jef.
Fab
I have the impression that this style is attributed to the area of central France and Beligium, possibly overlapping into some regions of present day Germany.
As one moves towards Southern France the examples sold by antiquities dealers seem to be fairly long (19" to 20") and shaped more like thrusting sword tips. Specimens offered as originating closer to Spain as well as SouthEastern Europe tend to remind me of long awl points rather than 2-D blade type shapes.
Just wondering if anyone else has the same impression.
Fabrice Cognot wrote: |
Anything else would be a bit depressing :P
He only made the spear typology to help date the swords.
Just out of curiousity, what is the State of the Art on these things?
This short graphic from 'Die Schweiz zur Merowingerzeit' shows the likely evolution of the winged spear. I hope this may help you, although it lacks some dating.
The second picture shows some winged spearheads found in south-western Germany. The piece in the middle is 52 cm long and has 8,2 cm wide wings. It was dated to the 9th. century. The shorter example on the right is said to show some merovingian influence in having a hexagonal socket and is dated to the 8th. century. the blade´s cross section is also more diamond-shaped, owing to avarian influence on the weaponry of this region and period.
Attachment: 117.06 KB
Attachment: 122.42 KB
Page 1 of 2
