Posts: 2,121 Location: Northern Utah
Mon 05 Mar, 2007 12:02 pm
Hugh,
Not to sound better than you or anything silly like that but some things to look over that I do on a fairly normal basis when I coem to this situation. When the results of a number of tests differ from my own testing I do two things. Look at my research and testing to see if and how it is flawed or look into the others research and see how they came to the results they did. I think the Royal Military Colelge in Sandhurst (I think) and the R.A. had tests on this as well that showed the backspike was able to penetrate but could not track down the refernce just yet, I will contact one of my friends at the R.A. and ask. I think Alan Williams also figured out the rough force on it and has a model of the factors of when and how it could penetrate, though I do not know how he went about doing this. After going over successful tests you may indeed find why their worked and faults with it or ways to focus yours.
As far as Bob Carrol. A great person I am sure but I do not think it really completely true. I think for sure there are examples of armour being degenerated to great lengths from corrosion or perhaps a few from over zealous care but there is alot of armour that I have handled both where I worked and at the R.A as well as other large collections that were either a, excavated or b, found in a castle/parish store that had rarely if ever been cleaned up and were rarely much different in thickness to others in the collections. I think over cleaning alittle on the lower cases list of armour destruction. Now talk about how people butchered pieces for trophies to hang over their tomb and I will go with it or decided to turn the backplate into a breastplate, yep have seen those but over
polishing, I have noted very little difference between the cleaned helmets in our collection and those which are not. That said out collection only has about a hundred and fifty or so helmets so it is a small sample in the long run but I think it gives a fair idea.
That being said I am sure from the armour I have seen thickness varied all over the place depending on the market and use. Who knows how a helmet of similar style if it was even remotely the same thickness. Even adding on thickness for degeneration your talking in the .0'smm or .00'smm not full on mm's unless Attila the curator was on duty at that time.
When I am back in the states I will let you know and perhaps we can set up a trial or something. My forge just sits dormant most of the year and I still have some medium carbon steel lying about. My parents live just a hop, skip and a jump away. My work keeps me pretty busy and I might not get a vacation back to the U.S. this year but I think the main issue of testing would be to show what allows the weapon to penetrate or not, heat treated, thickness, what part of the poleaxe is in use etc. I think the backspike seems most suited to over the dague but some of the halbards in our colelction have shapes similar to chisels.
Guilherme,
I do not think either is useless against plate. The hammer head to me seems more useful but I am sure the axehead could leave you thinking it was just as effective. Even a sword can ding you up inside armour. It will never cut through the plate armour but could still do you damage. I agree that the hammer seems like it would do you worse though.
