| Peter Johnsson wrote: |
| The COP is usually identified with the placing of the node of no vibration of the blade.
To me the nodes on no vibration offer a way to manipualte the stiffness of the sword during a cut. In popular understanding this has to do with the concept of "harmonic balance". As time has gone by, this term has been stretched to cover so many different aspects of a swords performance, it has almost lost its meaning. When vibration nodes are in focus I personally prefer to talk about node placing, as this is a more precise description. It seems that a common notion is that the placing of the blade node is of great importance for the cutting performance of the sword. I am not so sure about that. I do not think the blade node and the COP are the same thing. They may coincide, but this is just coincidence resulting from other aspects of the design of the sword. I´d say it is more important to note where and how the vibration nodes are placed in the grip, or hilt area. Try this out: Grasp the grip of the sword and hold it point upwards. Tap with the heel of your hand untill you find the node of the blade. You will notice how the whole blade becomes stiff and vibrates less as you tap in the spot where the node is. From a wobbly flexible blade it suddenly becomes more like a stiff plank. This offer us a clue to why the nodes play a role in the design of swords. The node is a place of stiffness where you can manipulate the rest of the sword without causing vibrations. Hence it seems to me that the nodes in the grip, that you will always grasp, are more important than the nodes in the blade. I say node*s* since there are vibrations of higher pitch with nodes placed on each side of the primary nodes in the blade and grip. These are not always aparent, but can be used to some effect in stiffening especially flexible or long blades. When cutting with a sword during an "agressive encounter with an enemy" you will not only use the part of the blade where the node is, you will cut with a longer section both inside and outside the blade node. *But* you will always grasp the the hilt in much the same place, and by doing this you impart highest possible stiffness in the blade druing a cut, if the placing of the nodes in the grip are optimal. Again, one must be aware that this is not a rule that has precedence over other aspects of the function of the sword. I have seen (original)swords that have their grip node placed *in front* of the guard. A strange and confucing thing to us modern aficinados, but it sems to work on certain types of sword. One of my most agressively cutting swords had the "grip" node placed 10 mmin front of the guard. This is clearly not according to the rules of how things should work. My guess is that the secondary nodes are put to good use in these instances. More research is needed here. COP has more to do with pivot points, and this is something else completely from vibration nodes. The no-shock effect that good swords are associated with is less an effect of the placing of the vibration nodes than the correspondence between pivot points in the grip area and the blade. (both these work together to some extent, but the vibration nodes are primarily an aspect of stiffness and only have a secondary effect on shock dampening) Placing of pivot points also have a big effect in the intuitive feel of the sword and what part of the edge/blade you get a direct dynamic feedback on through the hilt as you move the sword. -A feeling of "floating in the air" and "extention of my arm", is a result of effective use of the pivot points. -Does the blade pivot close to the vibration node as you move the hilt back and forth from guard to guard, or does the point seem to hover still in the air without moving from side to side even as you shift guard? You will see both these situations and everything in between on different types of swords. This is something you adjust according to the intended function of the sword. These are very important charactersitics for the feel of a sword. Much more important than where the balance point happens to be placed. (although this will of course have some effect as well). Of course Point of Balance, Placing of Nodes and Pivot Points all correspond with each other. If you want to shift one aspect without moving the others too much you need to work with the shape/dimension of the blade or lenght of the hilt. So, my take is this: Just as the placing of the balance point used to be a main concern some years ago, now there is a focus on where the nodes are placed. Both these aspects will tell you something of how a sword feels and performs, and are important in their own right, but they do not tell the whole story. The key to the dynamic balance, or intuitive feel of a sword lies in the placing of the pivot points. These also has a lot to do with how a sword delivers a cut. Pivot points, Node points and balance point are all spearate entities, but do have an effect on each other. If you want a sword that is more forgiving in what section of the edge you can use for best cuting reults, you want a sword where the corresponding pivot points from the grip are placed far apart in the blade. This is difficult to do in a slim and flexible blade with little variation in the distal taper. This is one aspect that non-linear distal taper hepls in more ways than one. By corresponding pivot points I mean this: imagine the part of the grip you hold that is closest to the guard, or most forward to the point. If you grasp this place sideways (edge to edge) between your thumb and index finger in a loose grip and "wiggle" the sword back and forth you will notice there is a section of the blade that hangs still without wiggling. This is a bit similar to finding the spot of no vibration in the blade, only that you do not slap the pommel. Instead you move the grip back and forth in a loose grip so that the part you hold can pivot between you fingers. (this is a quick and dirty way of doing this, but it works) You will find that the corresponding pivot point in the blade from the piovot point in the front part of the grip is placed somewhere between the vibration node and the point. Depending on how far towards the point in the blade this pivot is placed the sword will offer more or less precision in its point controll. If you now grasp the grip where the heel of your hand typically is when you wield the sword and repeat the wiggle test, you will find there is another pivot point in the blade closer to the hilt that correspond to this place futher back in the grip. You have now established where the extreme grip pivot points in the grip have corresponding pivot points in the blade. Typically there will be a longer distance between the pivot points in the blade than the distance between the pivot points in the grip. This will tell you roughly where you will make the most efficient cuts. But do not take this too far as there are other factors having an impact on this as well. |
O.K., I have known of the existence of balance points on swords for a long time. What i didn’t know is haw varied they were. I also was entirely ignorant of nodes and pivot points. I’m simply wanting to know from people who know what there talking about more details about them. Like, I always assumed the the balance point was just infront of the hilt, but allot of swords seem to have them several inches away. When I was younger, me and some friends would have sparing bouts with swords made of steel and aluminum alloy (mostly aluminum) pipes that had all except a 10” section at one end flattened to mimic a blade. This were pretty cool, and the fact that you could get hurt with them was one reason we really liked them. After learning about Balance points, I filled the hallow handle with some peases of steel until the balance was right infront of the hilt. At first I thought it was awesome cause i could move my blade around faster then my friends, but I quickly found that when trying to block my sword would usually get knocked around allot instead of being any good at deflecting the sword or stopping it. My point? What is the best placement for what kind of blade? I want to know more about the the structure of a blade.
P.S. Though I will not be able to buy anything for a wile do to a low income job. Some books that give some details would be cool to. I mite be able to find them at a library.
P.P.S. Some of you might recognize me from the Straight vs. Curved thread, what would the deference in the balance points, pivot points, and nodes be between straight and curved swords?
