This weekend I did my first serious attempts at casting bronze swords, using only methods and materials of the bronze age. Beyond my expectations, I got two complete swords out of 6 attempts! I know there have been some partially succesful attempts by others, though as far as I'm aware none start to finish using only bronze age techniques, and casting swords with the correct shape, weight and balance. The swords aren't perfect yet, as the surfaces are quite rough in some areas, and one of the swords has shrinkage porosity in the hilt. But they can be made into servicable swords, with some esthetical flaws. But I've got a pretty good idea how to improve on this in future casts.
Full view of the swords straight from the mould:
Close up of the hilts:
More information and photos of the process can be found here:
http://1500bc.com/bronzeage/bronzes/nf_carps_...d_eng.html
And a photo of one of the castings:
http://www.flickr.com/photo_zoom.gne?id=269290906&size=l
Congratulations! Great success. So, are the stone (well, they look like stone to me) moulds that I've seen in museums not genuine bronze age, or was there more than one technique for moulds in use in that period?
Geoff
Geoff
Thanks, that's really fantastic, Jeroen! What's the next step?
| Geoff Wood wrote: |
Geoff |
| J.G. Hopkins wrote: |
| Thanks, that's really fantastic, Jeroen! What's the next step? |
| Jeroen Zuiderwijk wrote: | ||
But what about with these babies in particular? Cleaning up, polishing, furniture...? :)
Great work Jeroen!!!
Thanks so much for sharing your enthusiasm....
Makes me want to go out an melt some bronze :D
ks
ks
Very impressive, Jeroen. Please continue to keep us informed on your progress with these pieces.
| Mikko Kuusirati wrote: | ||||
But what about with these babies in particular? Cleaning up, polishing, furniture...? :) |
| Jeroen Zuiderwijk wrote: | ||||||
Very interesting and I'm looking forward to see it finished. Are you going to work harden the edge and see how sharp you can get a bronze sword and how well the edge holds up to light cutting ? I'm thinking more of edge wear through abrasion than dulling when doing heavy cutting.
It depends on your objectives: Mostly aesthetic, functional weapon or a bit of both.
Sort of wondering if it's true that a hardened bronze sword could be superior to an early iron age sword of low carbon or hit & miss heat treating closer to pure iron or very mild steel: Better edge holding for the high quality bronze sword ?
Oh, how flexible or shock resistance can a bronze sword be ? i.e. NOT brittle ! I would guess the type of bronze alloy might make a big difference. If very brittle I would think hammer hardening wouldn't be practical ? The work hardened bronze might become brittle as well as harder if one overdoes the hammering ?
| Jean Thibodeau wrote: |
| Very interesting and I'm looking forward to see it finished. Are you going to work harden the edge and see how sharp you can get a bronze sword and how well the edge holds up to light cutting ? |
I've got a pretty good idea of how bronze hardens and functions by making and using bronze knives, axes etc. I've also done some tests on (non authentically cast) bronze swords to see how they hold under edge on edge contact. You get nicks a few mm into the edge, but that's about it. The bronze hardens on impact, and a work-hardened edge does not deform all that much. The damage also matches the originals I've seen closely.
| I'm thinking more of edge wear through abrasion than dulling when doing heavy cutting. |
| It depends on your objectives: Mostly aesthetic, functional weapon or a bit of both. |
| Sort of wondering if it's true that a hardened bronze sword could be superior to an early iron age sword of low carbon or hit & miss heat treating closer to pure iron or very mild steel: Better edge holding for the high quality bronze sword ? |
| Oh, how flexible or shock resistance can a bronze sword be ? i.e. NOT brittle ! I would guess the type of bronze alloy might make a big difference. If very brittle I would think hammer hardening wouldn't be practical ? The work hardened bronze might become brittle as well as harder if one overdoes the hammering ? |
