Posts: 109 Location: Bonn, Germany
Tue 08 Nov, 2005 9:13 am
A very nice thread with very good and interesting responses.
I agree that single handed sword +
shield means an significant advantage vs. a sword alone, especially agains a longer sword and if the shield fighter is fighting aggressively.
I once had a couple of "let's try this"-fights using a longsword against a fellow fencer with single handed sword and buckler.
It was a little frustrating at first, because he was alway trying to close distance very fast, while covering/ shuffling my weapon aside with his buckler.
After some glorious defeats ( trying to attack frantically while stepping/ stumbling backwards/ sideways, trying not to make him get close), in got used to the situation and tried getting his buckler away from his center and attacking a different opening, without moving too much.
I started with a classic right Oberhau and quickly struck a Zwerchau under his buckler, as soon as his buckler blocked my first cut. Because he was rushing in, the Zwerchhau went right across his stomach - would have been a fatal blow. The only problem was that he hit me directly on my left elbow, that was way up high, because I was doing the Zwerch... ouch. :confused: That day made me wear elbow protectors to sparring ever since...
My suggestions for the "no shield-fighter" would be:
Against a buckler: Try to strike around the buckler with feints/ windings,
Against a larger shield: Try to make you opponent impede himself with his own shield
Both are easier said then done, though... maybe moving to one of you opponents sides might offer an advantage...
(Edit, typo)
