| G. Scott H. wrote: |
| As for the durability of such construction, their may indeed be greater stresses on the hilt, as Patrick suggested, than on a hot peened hilt, but is the difference really great enough to make a lot of practical difference? |
This may sound like semantics, but I would love to see people get away from calling Albion's entire method of assembly "hot peening." The peening, hot or cold, is only one step in the assembly and is arguably not the most important. Albion's method of construction might be better called the wedged components assembly. You could hot or cold peen with their method.
The stresses Patrick speaks of are created by the fact that compression holds all the parts together. This can be done either with peening or with a pommel nut holding the components together. Cold peening would be necessary in the compression assembly to keep the grip from being heated up and destroyed.
The hot peening isn't the defining element of Albion's assembly, it's one step. The individual pieces being permanently wedged is what lessens stresses on the parts and helps ensure the solid nature of the assembly. It's a bigger and more important part of the process, IMHO.
Just my 2 cents. :)
