Vaclav N wrote: |
I've already read that article and the blade cross-section is really fullered, but the fuller looks to me something between narrow and broad. |
Vaclav N wrote: |
It really looks like type XIIa but isn't the dimension of this sword too big for this type? The length of the blade is 35" (90 cm) and the length of the grip is 8" (20 cm) and I guess it should be basically hand-and-half sword. Could it be this type even though? |
Nathan Robinson wrote: |
The fuller is a completely different element than the cross-section. It's often difficult to figure out of it's a hex, lenticular, or diamond with that fuller dug in there, but if you look at the areas above and below the fuller (the areas without a fuller), you can hopefully figure it out. |
