I have a bronze sword project, and I am in need of ideas & suggestions.
I've had this Neil Burridge bronze rapier sitting around for almost 10 years, and I finally decided to do something with it. It is a Mycenaean Type Ci rapier. I obtained it from Neil when this sword was still in the development phase, and it came to me rough from the mold.
A little background of the process to get to this point, then I'll pose my question(s).
The original pommels were marble or ivory, neither of which I have, so I turned the pommel from African Ebony.
I used Greek Olive wood for the handle scales. I glued the scales to the handle and drilled the holes for the handle pins. Unfortunately, when I started rasping the handle to shape I broke into some large worm holes. So I had to patch and fill-in the holes. I used brass pins and washers instead of gold.
Neil Burridge Mycenaean Type Ci Rapier
OAL 30-5/8"
Blade length 24-5/8"
POB 4-7/8"
Weight 25.4 oz.
OAL 77.8 cm
Blade length 62.5 cm
POB 12.4 cm
Weight 719 g
The scabbard... Well, we all know that distinct lack of detailed information about Bronze Age scabbards. For this project I pieced together a scabbard using a variety of source. Very thin wood core, spiral leather wrap, brass locket with chasing, chape with a tassel.
I am stuck on the baldric strap. I made a 1-1/2 inch wide strap. I was going sew the strap onto the scabbard as shown, but that seems decidedly unsatisfying.
Got any ideas?
I was thinking of making a brass locket at the the throat with a ring behind the scabbard and hanging the scabbard vertically. Or even making two brass lockets to hang the scabbard more horizontally instead of the sewing the straps. I'd do this, but I don't see any evidence for rings on lockets.
Ideas? Suggestions?
One last question. I left the blade somewhat unfinished. I spent a lot of time grinding and polishing, but there are still a lot of pits and imperfections. How finished were these blades? Should I keep polishing, or leave it alone?
