4th-5th century spatha with wide guard
Scroll down a bit https://www.roma-victrix.com/summa-divisio/armamentarium/pugiones-gladii-et-spathae/spathae-i-v-sec-d-c.html Any info on this? Is it legit and is it roman?
Wacky. Mind you, the late Roman stuff isn't my strong area, but it's certainly not like anything I've ever seen. So my guess is that either someone dropped a later guard (maybe MUCH later) onto the tang, or someone took a much later sword and stuck that chape on the tip. OR all 3 parts were just stuck together and don't really go together.
Some of the other blades on that page, well, let's just say I'm a little skeptical of their dates, not that "4th-5th century" is very precise. Just gut reactions.
Matthew
Are you positive it's a guard, or potentially a scabbard fitting? The tabs on the ends could be part of a suspension system of some sort. Given the prevalence of organic grips, including pommel and guard, in that era, and the presence of the chape, I'd lean more towards fitting than cross. Speculation for certain, but possibly within the real of reason.
It's actually not that wide. If the tang is 13 cm long then the guard (if that's what it is) would be about 8.5 cm wide. There are plenty of guards wider in this period. It's the shape that's unique.
It's MUCH more like some later guard than *any* suspension system I've seen, Roman or not. So I'm still voting for some kind of mashup.
Matthew
Here's another roman sword with a unique guard (half way down) https://www.academia.edu/41330119/The_Roman_sword_from_the_Przeworsk_culture_cemetery_at_Jadowniki_Mokre_Ma%C5%82opolskie_province
[edit] Here's a better pic: https://frisiacoasttrail.files.wordpress.com/2020/10/millingen-aan-de-rijn-ad-1-50.jpg?w=1024 Maybe this is just a normal guard plate that's folded over. I can't tell.
These are migration period swords from museums in Russia: https://www.academia.edu/38112923/Great_Migration_period_Swords_in_the_museum_collections_in_Central_Russia
It's a small picture but look at the sword laying down in the first group of pics. I don't read Russian but it looks like I'm seeing iv to vi century at top for these.
That's a very common first century BC Mainz-pattern gladius, with a brass guard plate that's bent along the middle. It would have been flat, and set into the base of a wooden guard. So it's not a guard by itself.
You mean the one lying on the newspapers? If you're looking at the little triangular feature at the tip of the guard, could that just be something printed on the paper, not on the sword? Otherwise, it's a tiny photo of a lump of rust...
Sorry, I'm not helping, there!
Matthew
Yes, it's too small to tell. Here's an earlier carving with a wide guard: https://holylandphotos.org/browse.asp?s=1,3,7,20,110&img=TWNAPM08
[Edit] Probably meant to be a Greek sword.
I read the article. About this sword's guard it says "guard is diamond shaped, up to 10cm wide (8cm preserved), 1cm thick".
There is no precise dating given, just a range of late IV to early VI cc.
Actually the pictures immediately to the right of the old one you were looking at are of the same sword, taken recently.
Hope this helps.
Alex.
Definitely Greek, and probably wildly misdated! 4th century *BC*, I'd say, possibly 5th.
Matthew
Thank you Alex. Yes it helps.
Re: 4th-5th century spatha with wide guard
The sword seems legit but it's not Roman. It's of Hunnish / associated tribes / steppe nomad origin. Most likely, these swords were inspired by Sassanid swords, and perhaps Han dynasty jian as well.
This one:
may be Sassanid, in my opinion. Although Greek, like Matthew Amt suggested is also possible.
You can find more information here:
http://myArmoury.com/talk/viewtopic.php?t=197...mp;start=0
Paul, I think you're right. It has a similar look to this one from the crimea: https://get.google.com/albumarchive/112795803340452839061/album/AF1QipPr9n2PyJh67PqUTAiq0M5Pp0rB_eAA6YrJehzC
