What do you see here: https://www.clevelandart.org/art/1916.1897 Don't those look like theta rings on the chest?
I believe this is mail from Poland: http://muzeum.sanok.pl/images/stories/amm_3_p...iewicz.pdf
Quote: |
Don't those look like theta rings on the chest? |
It's either that or they are really tiny buckles. :D
A silvered brass mail shirt from Bulgaria: https://sagy.vikingove.cz/decorative-edging-of-mail-armour/
Some photos of a mail shirt I am trying to get some opinions about, as to approximate time and place of manufacture. Oh, and large areas of the shirt are of alternating riveted and solid construction. https://photos.app.goo.gl/busr55ZpAmiwZBXU8
James Arlen Gillaspie wrote: |
Some photos of a mail shirt I am trying to get some opinions about, as to approximate time and place of manufacture. Oh, and large areas of the shirt are of alternating riveted and solid construction. https://photos.app.goo.gl/busr55ZpAmiwZBXU8 |
Right over left overlap. Wedge riveting. Watershed peining. Alternating solid and riveted rows. My guess would be German, perhaps 12-14th C.
I was thinking German before 1370. It strikes me as a bit light to be a primary defense, so I would put it late enough to have a coat of plates at least. I will add more photos of other parts. Another fellow who has a good reputation for historical mail thinks the collar is European 15th century added to a high quality Islamic shirt. Islamic mail with a smooth underside is new to me, unless imported/captured.
I have added more photos. When you click on the photo, there will be a brief description of the photo in the comments. https://photos.app.goo.gl/busr55ZpAmiwZBXU8
Mongolian: https://montsame.mn/en/read/251489 Looks like it has a vertical weave.
Len Parker wrote: |
Mongolian: https://montsame.mn/en/read/251489 Looks like it has a vertical weave. |
The photo looks pretty dodgy and the description is wrong. It is physically impossible for it to have links made from 0.3mm wire and weigh 29 kg.
Dan Howard wrote: | ||
The photo looks pretty dodgy and the description is wrong. It is physically impossible for it to have links made from 0.3mm wire and weigh 29 kg. |
Not only 0.3 mm wire, but really damn wide rings too. :wtf:
This wire doesn't look very thin at all, either.
Perhaps somebody'd just messed up some of the units?
29 pounds thus about 13 kg, and 0.3 cm wire would make way more sense.
Look at the ID to wire thickness ratio on this: http://www.futuremuseum.co.uk/collections/peo.../mail.aspx Wish I knew what this is. They got the six in one wrong.
Also, they have this as medieval http://www.futuremuseum.co.uk/collections/peo...-mail.aspx but it looks roman to me.
Very little overlap: http://ancientpoint.com/inf/129469-section_of..._a737.html
Len Parker wrote: |
Very little overlap: http://ancientpoint.com/inf/129469-section_of..._a737.html |
I've notified the user that this is likely Roman, as the riveted rings are wound in a left-hand helix, rather than the medieval right-hand helix. The square wire rivets also look Roman rather than XIII century.
Thanks, Mart. I missed that. Take a look at this (front) https://vk.com/albums-11029306?z=photo-11029306_456271136%2Fphotos-11029306 (back) https://vk.com/albums-11029306?z=photo-11029306_456271135%2Fphotos-11029306 If that scale is right, the ID would be more than 10mm. Why is it the big rings are in fragments. I never know whether it could be for a man or horse.
14th century flattened mail from Grodno: https://vk.com/terra_teutonica?w=wall-11029306_108377 Looks similar to modern stuff only smaller.
Edit: They do sell 6mm ID that looks similar.
Edit: I think this is also being dated 13th century. Possibly an aventail.
Page 27 of 27
