I came across a drawing of Ralph de Stafford's efiggy and found a very curious heater shield not much bigger than a Buckler, and fastened to the sword-belt as just as one.
There are other references for small heater Shields by this date? Could they've been the first "Bucklers?"
By the way, since we're discussing Shields, is the smaller dizer Kite Shield of Kingdom of Heaven movie a transition model between the kite shield and the heater one? I heard the movie wasn't incorrect with the historicity of it
Transition-shape shield: https://i.pinimg.com/originals/1a/23/03/1a2303575ec16998d1e5fe67e13978fa.jpg
Attachment: 172.15 KB
You can see its proportion [ Download ]
Since we're talking about shields, I notice something at "End Him Rightly":
Both are using a sort of buckler-sized cavalry shields, like those used especially in tournments. What's the name of these shields, they're simply called bucklers or could they be what is called a "petit pavise", or hand pavise?
By the way, the lance rest in this shield has any usefullness at all?
They aren't drawn to scale. Look at how short the lances are. The artist isn't trying to portray a photo-realistic scene; he is trying to teach the reader how to fight.
Dear Sr. Gaião,
This style of shield is called an ecranche. Jeff Hedgecock describes ones he makes on his business' site.
I didn't know this myself before looking at Mr. Hedgecock's site, but apparently the notches are functional early in the shields' history and non-functional later.
I hope this proves helpful.
Best,
Mark Millman
On Friday 24 May 2019, you wrote: |
[image snipped] Both are using a sort of buckler-sized cavalry shields, like those used especially in tournments. What's the name of these shields, they're simply called bucklers or could they be what is called a "petit pavise", or hand pavise? |
Quote: |
By the way, the lance rest in this shield has any usefullness at all? |
Best,
Mark Millman
Thanks for all the information,
I find this odd effigy, representing Guillaume Duchastel and dated 1444 (according to a certain Antonin Chenel). The small shield appears again:
I'm not sure that shield is contemporary with the effigy. It appears to be metal, perhaps added to place show the deceased's arms - it certainly seems to have the Du Chastel arms.
I note that the shield does not appear on modern photographs of the monument e.g.
http://www.churchmonumentsgazetteer.co.uk/Fra...u_Chastel_
Pedro,
There are examples of smaller kite shields that were used alongside the more common flat-top kite shields in the later 12th and early 13th century. Calling them a "transition" shield may be a bit misleading, insofar that the other style of shields (both kites and flat top kites) continued to persist.
One example of this are the kite shields in the Morgan M.724 Psalter from 1155-1160 AD. Some of the shields shown here are unambiguously shorter than most of the contemporary shields. Presumably, these shields are not merely based upon the illustrator's imagination, but reflect actual shields that really existed. What's noteworthy is that this is right around the time when flat top kite shields were starting to become common, and these latter shields dominated probably until around circa 1200 AD. So this is certainly one instance where calling shorter shields "transitional" could be misleading.
http://manuscriptminiatures.com/4684/12322/
As for the Kingdom of Heaven shields, the most likely historical inspiration for the shape (if they were inspired by historical research) is from the Liber ad honorem Augusti sive de Rebus siculus, an Italian manuscript (likely southern) dating from 1194-1196 AD:
http://manuscriptminiatures.com/3966/11577/
Dan Howard wrote: |
They aren't drawn to scale. Look at how short the lances are. The artist isn't trying to portray a photo-realistic scene; he is trying to teach the reader how to fight. |
those are spears not lances, this is a manual from an armoured judicial duel this arnt cavalrymen who have dismounted
There are other references for small heater Shields by this date? Could they've been the first "Bucklers?" |
Returning to the original question, the shields on this monument are particularly small, regardless how they are carried (most are on a guige on the left shoulder). Though shields were getting smaller, in this instance they are probably reduced for compositional reasons.
http://effigiesandbrasses.com/search/?year=13...;genders=M
As can be seen, displaying the shield at the hip, often hung over the sword hilt, was common. How practical this was in life, one might question.
A number of brasses like Stafford's have smaller heater shields. This may have been done simply to avoid having the shield obscure so much of the decedent. Also, a number of brasses had enamel on shields. Perhaps the brass' maker couldn't or didn't want to enamel a full-size shield (that could be a lot of glass to melt). Granted, this is complete speculation on my part.
Effigies (3D quasi-statues) are totally different than 2D brass slab effigies, of course.
Talhoffer buckler halfway down page,
http://www.stgeorgearmoury.co.uk/5501.html
looks the right size,
ref is mentioned, just a fyi, if of interest,
always liked the look of one,
