Dutch Rodeleros and related questions
I find this in a group of HEMA, when some people were saying such dutch sword-and-targe soldiers are product of spanish influence in the Netherlands, but I don't remember of any reference of them in battles or even as bodyguards. One was claiming that such soldiers were used under Nassau's wars against Spain, and although I actually have seen such style of helmet among modern dutch helmets, I don't know if they already existed by 16th century, so I would like to know your opinions.
Observation: Nassau was greatly influence by Machiavelli's work in warfare, where he defended the revival of sword-and-shield infantrymen the romans used. So it wouldn't be impossible if that was a real correlation. Check this image from late 16th century, for example:
https://www.rijksmuseum.nl/en/collection/RP-P-OB-9980
Another Observation: Due to Spanish influence, Portugal used rodeleros as well, they are greatly recorded in their wars in India and Thailand. For those who know portuguese, here is an article I translated:
"Also here, after the extinction of the captains, naíques, espingardeiros (harquebusier or musketeer) and peões (ie. foot infantrymen) inherited from the pre-portuguese period, the military corps was extraordinarily increased in the time of the governor Fernão Teles de Meneses (1581).
Besides the captain and his close soldiers, were set places for 82 espingardeiros, 80 flecheiros (ie. archers or crossbowmen, probably the last one) and 83 rodeleiros (ie. portuguese for "rodeleros"), commanded by 5 naíques, resorting to local allied troops, in order to ease the shortages of men-at-arms.
Source: p. 146 from: https://run.unl.pt/bitstream/10362/9389/1/tese_andreteixeira.pdf
Some notes:
1. "Espingardeiro" was a generic term for any firearms employed soldier. It firstly meant a handgunner in 14-15th centuries, but also meant a harquebusier and probably musketeer as well.
2. Don't know that "naíque" means, but probably refers to some sort of officer in portuguese overseas' domains
3. "Flecheiros" would literally be translated as "arrow-er", but more specifically an archer or crossbowmen. Portuguese terminology is always confusing, since term like "besteiro", "archeiro" and "flecheiro" could equally means crossbowman, but "archeiro" and "flecheiro" meaning archer as well; english longbowman at Aljubarrota (1385) being refered as "archeiros ingleses", for the sake of example. Given to the ambigously usage, I prefered the term crossbowman because, since late medieval times, there are no known references to archers in Portugal, but only crossbowmen, since all the weapons of non-noble soldiers were usually kept in King's arsenals and the crossbow held great place in portuguese warfare. Although the crossbowmen were loosing space to the Espingardeiros in the end of 15th century (ie. handgunner of harquebusier), the text seens to indicate they never fade out to exist. If there is complainment about the use of native archers in the portuguse garrison, a reader must be aware that native troop were put under a different type of organization and typhology, so they wouldn't be recorded in the same place as the portuguese-born troops.
Since we are discussing this, I would also like to ask if it makes sense to say this: since sword-and-shield soldiers were firstly introduced by italians and then adopted by the aragonese, it's actually reliable to say that most of spanish rodeleros were actually aragonese? Or they became as much as popular in Castile as it was in Aragon?
Information I got in Ian Heath's book:
Maurice of Nassau indeed fielded targetiers and pikers equipped with shields in the early 17th century. I posted some images from the 1625 English version of Adam Breen 1618 infantry manual. The dedicated targetiers in the 1625 manual look similar to the image you've got there.
As far as inspiration goes, I suspect it was a mixture of the longstanding Spanish (and general European) practice of using shields combined with belief in the efficacy of ancient Roman methods.
I suspect the influence is more classical, Machiavelli, or general European practice than Spain specifically. English military writers from the second half of the 16th century tended to have quite a bit of enthusiasm for targeteers, usually citing the ancient Romans. Robert Barret wrote that while nothing could withstand a push of pike on an open plain, "best for the myne or breach is the Target of prooffe, short sword, and Pistoll" and recommended that 2 or 3 infantry per hundred should be armed that way. Sword and target also remained relatively popular weapons for captains or other officers.
For the most part using targeteers or not seems to be presented as a matter of preference. Tactically they perform more or less the same role as halberds, bills, longswords, and other "short weapons": Backing up the pike square if it is disrupted, pursuing and executing routing enemies, entering into buildings, mingling among the shot to protect them in a melee, etc.
The Dutch Rondassiers are an intersting example of the difference between theory and practice.
"Rondassiers" could be found in units raised by the Dutch provinces before Maurice of Nassau, they appear in a number of musters from the 1570's and were never numerous, usually around 2-4 in a company with 3 being the most common number. They either took the place of the men with "greatswords" (slagszwaarden) or served alongside them.
Maurice and several other of the Dutch military reformers such as Johann von Nassau-Siegen were very interested in the used of Rondassiers and experimented not only with the common shot-proof steel target but also with the much larger shield seen in the image in the first post. These large square shields were not made to be shot proof and instead the Rondassier wore a modified version of the shot-proof armour used by cuirassiers.
If we look at the letters & documents that survive from the archives of Maurice and Johann one could easily believe that the Dutch were supposed to deploy Rondassiers in large numbers, particularly as a formal regulation for the drill used by the Rondassiers was published in 1618. But a look at the actual muster rolls show that the Rondassiers remained far and few between. The States General simply refused to introduce them in the numbers wanted by Maurice and the "heavy" Rondassier with square shield was probably never seen outside of Maurice's personal guard.
One probable reason for the refusal of the States General was the cost of the Rondassiers, the men were double-pay men and in all the musters I've seen they were invariably the best paid common soldiers. The equipment envisioned by Maurice was also expensive as shields, armour and pistols were all specialised and therefore expensive equipment.
That's useful to know. Commanders tended to want tons of expensive equipment when designing their ideal armies. Raimond de Fourquevaux, for example, specified some sort of armor for each and every soldier, if it were possible. In practice, this could be difficult to pull off. Similarly, commanders describing ideal armies tend to burden their soldiers with more weight than real soldiers usually wanted to bear.
Shield-and-sword armed infantry was also employed in England by that time?
Dutch companies were arranged in 400 men units? I didn't know the dutch also employed zweihander armed men among their infantry (those probably being more popular than rondassiers).
Do you know how old is such pratice of giving double pay to special infantry? I thought it was landsknecht stuff ...
Also, since fully armoured rondassier quite uncommon in dutch armies, what exactly was the most common (or minimum required equipment) for a regular rondassier? At least three quarter's munition armor?
Yes, just probably not in very large numbers. Take for example this diagram of an English square from Thomas Styward's 1582 book which shows officers equipped with sword and target stationed in front of the formation:
http://imgur.com/a/AJ4Dc
The "B" positions in the center of the pike square could also be partially replaced by targeteers in theory. However the main source of headache for most Elizabethan tacticians was that they still had tons of outdated billmen that they had to put somewhere.
There are also quite a few accounts of metal or leather targets being used in the english colonies in the early 17th century. Targeteers armed with pistols were apparently more useful against the native american style of warfare than pikes and halberds were.
They however did a great job at the Battle of Flodden.
That's true. But despite Flodden being seen as a decisive victory for the English bill over the continental pike, the attitude among english military men towards bills seems to have cooled dramatically during the second half of the 16th century. There was a broad agreement that England needed a much higher proportion of pikes, similar to other european armies, and many felt that it would be better to swap out the remaining bills for continental-style halberds or targets. According to Humphrey Barwick, the main reason for retaining the bill was just that it was more familiar and easier to learn for common folk than a halberd was.
In 1622, the remaining bills in the tower of london were lumped together with longbows and old coats of mail as being "unfitt for any moderne service here." About 1000 of them were then shipped overseas to the Jamestown colony, the thinking being that they would still be useful against the primitive arms of the american natives, but it isn't clear how much they were actually
Dutch companies varied greatly in size between time periods and the provinces, early on you could find companies that were clearly based on the German practice which were quite large at 300-400 men but also much smaller units of about 100-150. Companies became smaller as the war went on and by the late 16th Century companies would be more like 120-150 with the largest at about 200. (Again, with a lot of variation between regiments)
The Dutch infantry included a small number of men with two-handed swords as guards for the flag in each company, probably because of the influence from German military culture. (Landsknechts were formed to fight in the Netherlands by Maximilian and parts of the Netherlands supplied many of the early Landsknechts which fought in northern Europe or for France.) 1586 regulation set the number of two-handed swords to 4 in a company of 150 and 6 in a company of 200. By 1580's men with two-handed swords were not double-pay men, one muster shows them being paid f 10 while ordinary pikemen were paid f10-12, musketeers f11-12, halberdiers f9-10, arquebusiers f8-9, rondassiers f15-18
I have found the practice as far back as the late 15th Century among the Landsknechts, in its original form double pay was issued to officers i.e men that held military office which included not only those in command positions but also the standard-bearer, the drummers, the military scribe and the guide.
During the early decades of the 16th Century double pay was expanded to common soldiers, first and foremost the armoured pikemen who formed the essential front ranks of the unit, the system seems to have peaked in the 1530’s when men with halberds and twohanded swords could also be paid double pay depending on their position in the battle formation.
By the second half of the 16th century the usage of the word “doppelsöldner” changed and it usually but not always referred to armoured pikemen when found in narrative sources. (Administrative document usage is more complex and depends more upon the country in question)
The bonus pay system also changed and became increasingly complex with the bonus pay no longer being a simple payment of double pay. For example, in the 1590's the Bavarian troops raised to fight the Ottomans had a system with no less than 18 different levels of pay with the arquebusiers paid 5-6 gulden, the musketeers 8 to 10 and the doppelsöldner 8 to 24.
The double-pay system was part of the "German" military system which was more widespread than the borders of modern day Germany as its influence extended into the Low Countries and Switzerland and had some influence in Scandinavia as well. (And Landsknechts in Spanish and French service used it as well though the Spanish in particular controlled and adapted the system.) Other countries also developed their own forms of bonus pay system as they evolved professional armed forces, the Spanish had the Ventaja to name one example.
As for the armour of the Dutch Rondassiere it depended on the period, as a rule the men themselves favoured less armour rather than more because they already had to carry the heavy shot proof rondel. Based on illustrations some men made do with only helmet and shield, others added breast and backplates but no long defences for the thighs in order to keep mobile.
Double pay is even older than Landsknecht - in Polish mercenary foot-soldier units formed from 1450s pavise men, who also acted as "decurions", received double the pay of a crossbowman. In 1490s pikemen were introduced (in small numbers, they formed single row in front of the formation just like pavise men) that also received the double pay.
Mind if I ask what the "f" stands for?
The "f" stands for "Florin" which in this case isprobably the Dutch Guilder which was minted to the same format as the Florin. Could also be a German Rheingulden or Reichsgulden which was used as a standard in some mercenary contracts. It is not easy to tell as 16th Century currencies are complex and many used the "f" or "fl" abbreviation of the Florin in actual record keeping without writing down which actual coin was used...
https://en.wikipedia.org/wiki/Florin
Thank you Daniel!
Why two-handed swordsmen and halberdiers receive such low payments? Their importance that declined that much by this time or it was simply a dutch preference for pikemen and rondassiers?
That's kindda groundbreaking for me. If I'm not mistaken, you once said me that pikemen in the vanguard received more than other pikemen but weren't considered "doppelsoldner"(well armoured pikemen at the Siege of Viena or after it also received more than not-so-well armoured pikemen). Osprey's books often confuse me instead of clarifying (many contradiction regarding what the author said what a doppelsoldner is, as he simply ignores these definition latter in his book).
I thought halberdiers and two-handed swordsmen would be put in the 50-men space of the 100-men force that existed at each fähnlein's doppelsoldner (the fähnlein itself being +/- 400 strong), this always existed, right?
Their importance had declined and the service they provided was not considered essential to pay extra money for. Basicly the rondassier took their place as he was considered more usefull in both siege warfare and battle due to his shield. So in order to get men willing to equip themselves with the heavy and cumbersome shield they paid rondassiers extra. But the rondassier would soon follow them into decline as it was seen that it was the pikmen, musketeers and arquebusiers who did all of the essential fighting regardless of the situation. We can see this in the 30-Years war when the army of the Catholic Leauge had regiments that were supposed to include a couple of hundred halberdiers. In reality colonels converted halberdiers to pikemen as they had never enough of those while halberds were not as effective.
Your posts are fascinating Daniel. Can you recommend any reading about the development and composition of dutch armies during this time?
As for the pay, is there a distinction made between the pay for armored vs unarmored pikemen? what about the other soldiers?
