Not having much luck finding details about medieval leather helmets.
Specifically looking for information on leather helmets from the 14th-15th C that were slightly conical or dome shaped (like the cervellière), worn by lower-class fighters.
Perhaps called hunettes or huvettes.
Looking for
-detailed references
-extant examples
-detailed pictures in illuminated manuscripts
I would appreciate some assistance.
Thank you
https://fr.wiktionary.org/wiki/huvette
There's at least one source presuming the huvette is made of iron.
https://books.google.com/books?id=O-5cbzzU1JgC&pg=PA167&dq=La+entroient+les+Gandois+huvette&hl=en&sa=X&ved=0CCAQ6AEwAGoVChMIsP31rqj0xwIVyZiACh2BBAHW#v=onepage&q=La%20entroient%20les%20Gandois%20huvette&f=false
Gives the source as the Memoirs of Olivier de la Marche, I R I, p.401.
| Quote: |
| 1. Casque de fer.
La entroient les Gandois, armez de leurs jaques, haubergeons, panciers et huvettes. |
I haven't spoken French since I left Europe 30 years ago. I guess Google translate is my friend.
I am more interested in the poor-man's leather helms than the metal helms.
Here's what I get with Google translate:
"The entroient the Gandois, arm their jackfruit, haubergeons, panciers and huvettes."
It's all clear to me now! :)
| Mart Shearer wrote: | ||
It seems that the huvette was an iron helmet, not a leather one. What other term might have been used for leather helmets?
Gandois are men from Ghent. The root word for huvette simply means head, so I doubt the passage tells us more than that they were armored headpieces or helmets or some type.
So we are looking for qualifiers to tell us whether the helmet was made from metal or leather. You see the term steil bonnet in a lot of Scottish texts. The qualifier "steil" makes it clear that it is a metallic helmet. In French the qualifier is often de fer. I'm guessing that need to look for terms like huvette de cuir to find evidence of leather helmets.
The term cappados is used in a few Middle English texts such as Sir Gawain and the Green Knight. The best interpretation of this seems to be a helmet or hood made from Cappadocian leather. However these texts usually describe knights wearing it, not poor men. I'm not sure we can assume that a man who couldn't afford metal armour must have worn leather instead. In Western Europe, armour of any kind seems to be the preserve of the wealthy right up to near the end of the Middle Ages - regardless of whether it was metal, or leather, or cloth.
There are some references, though Earlier than Harry had requested.
In Lombardy, the Statuti Della Societa Dei Vari, 1256
http://archive.org/stream/statutidellesoc02ga...3/mode/1up
Cappella, being Italian for chapel, the similarity between the French chapel de fer is clear. The choice between the leather (coro) or iron (ferro) versions is approved, though the caçetam (cassetta - small box) is not allowed. I think this calls for leather or iron kettle hats, but not simple skullcaps. I'm not quite sure what the distinction between the iron and leather headpieces are which causes a different spelling - capelictam vs. capellum.
The Tournament at Windsor Park in 1278 uses leather helms (galee de cor.) and armor (quiret), along with baleen swords, so they're "sporting equipment". However, it's possible the maker, Rob'o Erunnler, had previous experience making leather helmets, which might have resulted in his contract.
Thom Richardson's thesis notes in 1344 and onward a kettle hat (capellos) of leather for the tournament (j de corio pro torniamento).
Since we have documentation for the covering of iron helmets with leather and cloth, it seems written sources for leather helmets are more definitive than pictures.
| Quote: |
| XXVIIII Statuimus quod quilibet de dicta societate
teneatur habere scutum et capelictam de coro vel capellum de ferro et non caçetam , nec debeant eas impignare. et ministrales teneantur una vice in corum mistralia rumare, non dicentes alicui. et si invenerint aliquem non habentem ad terminam ordinatos, offerant ei nomine banni .v. sol. bon. et nichilominus teneantur habere. |
Will McLean provides more references.
http://willscommonplacebook.blogspot.com/2014...nt-at.html
http://willscommonplacebook.blogspot.com/2014...nt-at.html |
That's the best reference that I've found so far, but not a primary source of data.
bump
