Hello all,
Florian Fortner and Julian Schrattenecker have just published a very interesting article:
Comparison of period rapiers with modern reproductions
It contains measurements for 7 antique rapiers and 5 modern blades. What makes it especially valuable is how thorough the measurements are; they include for example the total mass, overall length, blade length, point of balance, pivot points, and even measurements of cross-sections. They have used the method described in one of my earlier articles, which makes me very happy of course :) A very important reference for anyone studying rapier!
Really nice article and very informative, I hope a large number of people will read it.
It sums up everything I try to do with custom orders, with fewer budget restrictions, to get closer to the originals, like using blades starting at 8mm on the forte and a geometry that has a much stronger forte, but often the reply I get is "it is a bit heavy".
Quote: |
Another big difference between the original and the modern rapiers can be seen in the
thickness of the ricasso. All measured historical rapiers have a ricasso thickness of at least 8.3 mm and the thickest modern rapier is only 6.2 mm. This results in a very different way of handling of the sword, especially when pressure is present.... Most modern reproductions have a low weight but still feel comparatively heavy in the hand. The graphs of cross sectional area vs. blade length have shown that modern rapiers have an almost linear decrease in cross section area over length, which results in less relative weight in the forte of the sword and more in the debole. This arises due to economical production by stock-removal. Usually a 1/4" stock bar is used as raw material for the blade, which results in a thin ricasso. Diamond cross sections are preferred, because they are easier and faster to manufacture. |
Exactly.
Marco Danelli wrote: |
It sums up everything I try to do with custom orders, with fewer budget restrictions, to get closer to the originals, like using blades starting at 8mm on the forte and a geometry that has a much stronger forte, but often the reply I get is "it is a bit heavy". |
Hah. Rapiers are supposed to be 'a bit heavy'. They're not smallswords or fencing foils. They're a 'reach is everything' approach to the sword arts and are among the heaviest of the one-handed swords. I think people have been trained to have a different expectation of what a rapier is supposed to be.
The one thing which surprised me was including the A&A Lombardy. That is a sharp replica of a specific piece, so it should be compared to that piece and not to seven other swords.
Modern smiths often sell different blade types of the same length, so more details about the modern rapier foils would also help.
Quote: |
The one thing which surprised me was including the A&A Lombardy. That is a sharp replica of a specific piece, so it should be compared to that piece and not to seven other swords. |
The bright side being that when someone goes and measures that original, the comparison will be easy :)
The point of the article seems to be that there are trends in the sample of originals, and different trends in the sample of modern pieces, not really to compare sword to sword. Of course you could argue that this is not statistically significant. It's still way more significant than no data at all :D
Well, my point is that modern sharp replicas of specific pieces are different from modern foils are different from early 17th century swords. Trying to find a trend from four foils and one sharp replica does not seem wise. A&A sells plenty of rapier foils, although if they did not have one handy and not want to spend $700 to buy one I would understand.
I wonder if the KHM has any rapier foils from the sixteenth or seventeenth century?
Only two show up under "rapier".
http://bilddatenbank.khm.at/viewArtefact?id=372997
http://bilddatenbank.khm.at/viewArtefact?id=373000
You can always wade through the returns for "schwert".
http://bilddatenbank.khm.at/coll_gg
Sean Manning wrote: |
Well, my point is that modern sharp replicas of specific pieces are different from modern foils are different from early 17th century swords. Trying to find a trend from four foils and one sharp replica does not seem wise. A&A sells plenty of rapier foils, although if they did not have one handy and not want to spend $700 to buy one I would understand. |
Well, part of the point of modern foils is that they are supposed to have handling properties close to period sharps. It wouldn't necessarily be meaningful to compare them to period foils either, as it's possible that these were not meant to be as close to sharps as that. In truth I don't know, for lack of data of course.
Period foils are a lot rarer in collections. But I too would like to know more about them...
A measurement I'd like to see for swords in the future is rotational moment of inertia about a standardized point - the easiest point to establish this as is the center of mass, or rather, the point of balance. One can then use the parallel axis theorem to determine its rotational performance as held.
To be more constructive (but not too constructive, my apologies), the procedure to determine this is not at all too hard. I recall an experiment in physics class a few years back where we found the moment of inertia of a bycycle wheel. We set the wheel up on an axis (in this case... an axle) and let a given mass rotate the wheel. We then evaluated the performance of the rotated wheel to determine its moment of inertia. The precise procedure has escaped my memory, but being a commonplace experiment, I am certain it would be an easy one to dig up.
It ought to be fairly trivial to design a test apparatus for a sword - the inertia of the apparatus itself would be tared from the results before the conclusion of testing. This would be a useful tool for just about anyone interested in sword mechanics, as it would serve to illustrate just how much force one would need to put into any given weapon to inflict harm, at least in the cut.
...I realize that may have been a bit off-topic, but one can always hope for those wonderful historian-scientist hybirds.
Hi Michael,
I'm one of the hybrid here, though more scientist than historian by education :)
Actually they have measured moment of inertia here. That's why I stressed the thoroughness of the measurements! See, the thing is that pivot points are intricately linked to moment of inertia. For example, in the tables in the article, if you compute:
Total Mass * Dynamic Length * Point of balance
You have the moment of inertia around the cross. Use the parallel axis theorem as needed if you want it elsewhere.
The authors have used a method that I describe here:
A dynamic method for weighing swords
I think it gives results that are easier to relate to than raw moment of inertia.
If you want further things to read on this topic, I have two other articles:
Geometrical analysis of mass distribution
Visual representation of mass distribution
It is all still a work in progress at the moment. But the foundation that pivot points are a good way to measure and analyze moment of inertia will remain...
@ Sean Manning: The measured A&A Blade is not sharp, it is blunt and used for training. At the KHM we haven't seen any foil-blades.
Julian Schrattenecker wrote: |
@ Sean Manning: The measured A&A Blade is not sharp, it is blunt and used for training. At the KHM we haven't seen any foil-blades. |
Scott Wilson of Darkwood makes some blades with broad forti and narrow deboli. He thinks that these behave more like originals, but look less like sharp swords. Many swordsmiths today have to balance the desires of stage fencers, show fencers, the SCA, and serious students of a variety of 16th and 17th century arts.
