After battle or maybe practice, swords get scratches. I use scotchbrite heavy duty and a bit of CLP oil. After running it down the blade relatively lightly about 10 times or more, it usually does a pretty good job of taking light scratches out.
They didn't have scotchbrite 1000 years ago so if known what techniques did they use to cleanup their steel?
Artwork suggests they had leather strops which were presumably used with some kind of abrasive.
Mike Ruhala wrote: |
Artwork suggests they had leather strops which were presumably used with some kind of abrasive. |
By any chance do you have a link to some of this artwork? I'm wondering if they took the sword to the strop or the strop to the sword and how exactly they ran it down the blade, or the blade down the strop.
Looking at museum swords it seems they didn't much if ever, i'm guessing they would have the sword re-sharpened and polished every now and again and that by default would remove the scratches.
But on an everyday or use basis? No way... its just to time consuming for any real benefit.
Now taking care of the edge that's another story, but an edge ( or two ) can't compare to an entire sword!
Abrasives were and are everywhere.
GC
GC
I attached a pic of the strops for you. Scotchbrite is more efficient but strops are effective. They also had large stone wheels of the type that were used in the cutlery industry well into the 19th c for shaping and sharpening. Polished swords cut better and that's probably got something to do with why we hear so many old stories about legendary swords shining brightly in the so and so forth. The blade doesn't have to be mirror polished all the time or anything like that but every bit helps a little, people have done experiments with modern paints that have engineered-in lubricants and have noticed a boost to their cutting performance. The H/T's will cut better if you polish them up a bit, too. Oh yeah, polished surfaces resist rust a little better as well.
Attachment: 59.38 KB
there are refs (although not to hand) of various mills renting out grinding stones for use by cutlers. Winchester springs to mind, its mentioned in a dig report. What type of gringding, rough, middling or finishing/re-polishing isn't mentioned.
I attached a pic of the strops for you. Scotchbrite is more efficient but strops are effective. They also had large stone wheels of the type that were used in the cutlery industry well into the 19th c for shaping and sharpening. Polished swords cut better and that's probably got something to do with why we hear so many old stories about legendary swords shining brightly in the so and so forth. The blade doesn't have to be mirror polished all the time or anything like that but every bit helps a little, people have done experiments with modern paints that have engineered-in lubricants and have noticed a boost to their cutting performance. The H/T's will cut better if you polish them up a bit, too. Oh yeah, polished surfaces resist rust a little better as well. |
Oh whoa, that's very interesting. Too think there would be an old drawing of even the cleaning of a sword too. Very good :)
Interesting stuff! And here I am over here just worrying about my edge and deep mars... So... I can gain more performance with a higher polish maybe? I'll have to dingy up some swords that I know how to cut with and then polish them bright and test this out. I expect it to be more up to me then the polish..... but it is interesting all the same. Cool ^^
Ryan A. Currier wrote: |
Interesting stuff! And here I am over here just worrying about my edge and deep mars... So... I can gain more performance with a higher polish maybe? I'll have to dingy up some swords that I know how to cut with and then polish them bright and test this out. I expect it to be more up to me then the polish..... but it is interesting all the same. Cool ^^ |
Note that the difference is very small, even marginal. Unless your technique is very precise and consistent (or your blade very roughly finished to start with :)) you probably won't notice much of an effect because other factors will completely overwhelm it.
It can add up to more than you might think though depending on the target. For instance on tatami a mittelhau is harder to perform as cleanly as a zornhau because of the extra friction of the mat pressing down against the blade rather than falling away. In real world terms it would be a marginal gain but it is noticeable.
